Thin Rip Jig
Forum topic by lew posted 116 days ago 238 views 3 times favorited 11 replies Add to Favorites
View lew's profile
lew
1751 posts in 292 days
116 days ago
Topic tags/keywords: jig table saw ripping thin strips
I have been trying to make a few cutting boards for Christmas projects. (You Lumberjocks that have posted your work do not have to worry about any competition!) Anyway, I needed to rip a bunch of thin strips for glue ups and thought about the jig, that several folks commented on, from Rockler.
Well, I am cheap. And besides- Rockler ripped off my idea (Woodcraft Magazine Nov. 2005) so, to get even, here is my improved version. It lacks the measuring scale but we all double check with a rulers anyway.
To mount this (and my feather boards) to the table saw, I made some special bolts. Using a washer slightly larger than the Miter gauge slot (my saw has an additional, wider slot at the bottom of the “regular” 3/8” miter slot), I had the washer welded to the head of the bolt. Then ground two flat spots on opposite sides of the washer so it would slide into the bottom slot and not turn. The bold head is 3/8” across so that also locks into the table slot. If you don’t weld and are close to a Technical school- you can probably get this done for nothing. Get a bunch made so you don’t have to switch them every time you change a jig.
You can even get away without buying any knobs by using the information posted by Lumberjock ChuckM http://lumberjocks.com/projects/8920
Lew
View Joe Lyddon's profile
Joe Lyddon
170 posts in 589 days
116 days ago
Just curious… couldn’t that washer have been Epoxied to the bolt head instead of welding?
Maybe JB Weld would work?
I don’t have a welder…
Nice, simple design!
Take a look at my website… There is another jig that does the same thing…
http://www.woodworkstuff.net/EFeaRip.html
-- Have Fun! Joe Lyddon - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=1389"
View lew's profile
lew
116 days ago
Joe,
Man, I like your jig! The addition of the feather board make it perfect! Wish I had thought of it :>).
Lew
View Sac's profile
Sac
203 posts in 170 days
116 days ago
Great Idea Lew. I was wonder about the JB Weld as well. Great Idea with the washer. Something I hadn’t thought about and the link over to the Hand Made knobs was excellent. Thanks!
-- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's
View tenontim's profile
tenontim
960 posts in 281 days
116 days ago
This is what I do with the little wooden feather boards you get for a couple of dollars at(?). When the “feathers” break off, I make stops out of them like this. I just cut about 200, 1” corbels, to use for crown molding in my house, using a jig similar to this. If you don’t want to weld the washer on, grind the head of the bolt down to a thickness that will fit in the T slot with the washer on the other side of the head.
-- Tim -- http://tmuli.com
View PurpLev's profile
PurpLev
355 posts in 185 days
116 days ago
nice jig!
-- My Drinking Club has a Woodworking Problem...
View lew's profile
lew
116 days ago
When the knob is tightened, it pulls up on the bolt to pinch the jig tight to the table. The places a lot of pressure on the washer. I have never used JB Weld and cannot speak to its’ strength. I have used silver solder to fasten the washer to the bolt and that is holding. I would have liked to use closet flange bolts but my miter slot is too wide.
Lew
View jeanmarc's profile
jeanmarc
1753 posts in 253 days
116 days ago
Great Idea
-- jeanmarc manosque france
Beginningwoodworker
787 posts in 210 days
115 days ago
Nice looking jig, Lew.
-- CJIII Future cabinetmaker
View fredf's profile
fredf
228 posts in 247 days
115 days ago
Instead of a washer, a piece of flat stock that will slip in the lower slot wont turn I think my delta the slot is about 1/8×7/8 . . . take 7/8 slices off of a 1/8×1 piece of black bar. Beware the fumes from the plating and galvanizing
-- Fred, Springfield, Ma
View lew's profile
lew
115 days ago
Thanks for all of the kind words and “tweaks”
fredf- I thought about that with my saw but the lower slot is really “thin”. The washer just about fills the gap.
Lew
View Bigbuck's profile
Bigbuck
1045 posts in 200 days
115 days ago
Nice jig, thanks for sharing I have been needing one of those but like you I am to cheap to buy something I could easily make. Thanks for sharing it with us.
-- Glenn, New Mexico
Bookmark And Share This Page
