Newbie question on finishes for a workbench
Forum topic by Brett posted 10-17-2012 02:30 PM 5266 views 0 times favorited 17 replies Add to Favorites Watch
View Brett's profile
Brett
661 posts in 2854 days
10-17-2012 02:30 PM
I’m nearing completion of a workbench made from southern yellow pine. I plan to rag on a finish of some sort. The workbench has a shelf made of ship-lapped ash boards where I will place tools, wood, etc.. Should I use the same finish on the shelf, or should I leave it natural? If I use finish on the shelf, should I put the finish on the boards before I nail them in place, or should I do it afterwards?
(Sorry if this question is too basic; I’m still a beginner at most aspects of woodworking.)
-- More tools, fewer machines.
17 replies so far
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3330 days
#1 posted 10-17-2012 03:24 PM
Brett:
I would finish the bench, shelf and all, with an oil of your choice, something like a Danish oil that will not build up a film finish and might give the yellow pine a more satisfying color (at least for me). Film finishes are easily damaged on a workbench and start to look bad in short time…whereas they must be stripped. Oils are easily replenished. Top with a good wax to provide some good moisture/chemical protection, satin look, and feel.
Pre-finish the shelf if you can’t cover the surfaces well, such as with spraying in nooks & crannies. If you pre-finish, do not apply it to glue areas.
Grats on the new bench!
-- jay, www.allaboutastro.com
View RussellAP's profile
RussellAP
3104 posts in 2458 days
#2 posted 10-17-2012 03:27 PM
Danish oil for sure.
I would really consider using some other wood than yellow pine, it’s primarily a construction wood. It gums up tools an rarely takes a finish well. It’s okay for a bench, but I’d use some other wood for anything I wanted to look nice.
117270 posts in 3748 days
#3 posted 10-17-2012 03:29 PM
Here’s a good finish. http://www.generalfinishes.com/retail-products/oil-base-top-coats/arm-r-seal-urethane-topcoat
It will be much easier to prefinsh the the shelf before installing it.
Cosmicsniper
#4 posted 10-17-2012 03:47 PM
Russell:
Chris Schwarz recommends southern yellow pine because it IS a construction wood. It is cheap, found at the big boxes, and you can get a really thick laminated surface by milling and gluing up the bigger 2×6s, 2×8s, or larger.
I’m with you with regard to looks, but it a solid, cheap way to get a really heavy, durable top. It’s certainly not the easiest wood to work with or to finish, but for hand plane guys it’s a smart choice, especially if you can’t afford the traditional, rough cut sized maples, beeches, ashes, or even oaks.
Cosmicsniper
#5 posted 10-17-2012 03:50 PM
BTW, the pine really appeals to me. As much as I want to build my own heirloom hard maple bench out of 8/4 stock, it’s not truly a necessity, IMO.
View PurpLev's profile
PurpLev
8541 posts in 3820 days
#6 posted 10-17-2012 03:58 PM
I’d just finish it all (top, base, and shelf) with BLO (which I did on mine). the finish will protect your workbench from moisture and other elements and give it a warmer tone without creating a plasticy film on top that will be hard to refinish in the future. wipe it on heavily, wait 15 minutes, wipe off excess… done deal.
View Francisco Luna's profile
Francisco Luna
943 posts in 3565 days
#7 posted 10-17-2012 04:14 PM
oils are the best way to go. Once dry, just apply wax periodically. Tung oil worked 4 me.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View Gshepherd's profile
Gshepherd
1727 posts in 2373 days
#8 posted 10-17-2012 04:29 PM
Ditto on the Danish oil…......I always use the GF brand natural not the tinted stuff.
-- What we do in life will Echo through Eternity........
View HorizontalMike's profile
HorizontalMike
7770 posts in 3085 days
#9 posted 10-17-2012 04:41 PM
After an oil “Johnson’s Paste Wax”. Cheap and very good.
View Woodknack's profile
Woodknack
12398 posts in 2551 days
#10 posted 10-17-2012 04:52 PM
I would use Danish oil or a thinned coat of shellac. I used BLO on my yellow pine workbench and over the years it attracted dust and became gummy; eventually I scraped it off and just left it plain. Maybe the problem was I used too much or maybe it’s the combination with pine but I wouldn’t use it again. Over time I’ve become a shellacophile, it’s easy, fast drying, durable, and repairs (if needed) are simple but I would stick with maybe two light coats to seal the wood a bit so dust and dirt don’t become embedded in the wood. Danish Oil is fine, it’s just that every time I use it I end up wishing I’d used something else.
Also, ditto on the wax.
RussellAP
#11 posted 10-17-2012 05:40 PM
Cosmicsniper, I just hate the way it gums every tool I have up. Around here we have more white pine than anything else at BB stores. A little bit of douglas fir and lots of cedar. I don’t even want to think about what yellow pine would do to my ORS’s.
RussellAP
#12 posted 10-17-2012 05:42 PM
I think that out of all the oils, danish natural gives you the best bang for your buck as far as making grain pop. I’d likely leave my workbench natural though, no need to use any thing on it because it’s going to take mucho abuse anyway. I usually spill enough oil from other projects to cover most of it anyway, :)
Cosmicsniper
#13 posted 10-17-2012 05:58 PM
No, I get that, Russell. It’s a trade-off to be sure. But it should be mentioned that southern yellow pine is substantially harder than white pine, with almost twice the Janka scale rating. I would be afraid of durability with the white pine, as well as the weight for handplane guys.
Cosmicsniper
#14 posted 10-17-2012 06:06 PM
BTW, we are talking about ideals here. I’m not a workbench snob in this regard. MDF and plywood make for excellent workbenches as well. My father, while not a hand plane guy, has had his plywood benches for as long as I can remember.
There’s something equally appealing about a top of two laminated 3/4” or 1” MDF boards with a thin, replaceable hardboard atop of it. Heck, that’s only one sheet of MDF ripped down the middle. If you need it deeper, you could incorporate a tool tray.
I might do something like that for an TS outfeed/assembly table.
View Monte Pittman's profile (online now)
Monte Pittman
29953 posts in 2509 days
#15 posted 10-17-2012 06:07 PM
Anytime you can finish it is preferred. You’ll get a much more natural look to the project. Danish oil for the bench.
