Makita Router Question (RF1101 varible speed)
Forum topic by Howie posted 10-16-2012 10:04 PM 2719 views 0 times favorited 8 replies Add to Favorites Watch
View Howie's profile
Howie
2656 posts in 3162 days
10-16-2012 10:04 PM
My router (after 7 years) has decided to speed up and slow down. I checked the brushes and they don’t look that bad. Controller board?? Anyone got a suggestion?
-- Life is good.
8 replies so far
TopamaxSurvivor
18424 posts in 3915 days
#1 posted 10-16-2012 10:50 PM
probably, if the power is not cutting in and out.
View Roger's profile
Roger
20965 posts in 3043 days
#2 posted 10-16-2012 10:57 PM
Hope you’re not using an extension cord???
Howie
#3 posted 10-17-2012 12:23 AM
No extension cord. Not much left but the controller I guess.
Top—power is steady. Router runs,just surges.
I can order a new controller for 75 bucks. Still cheaper than a new router. This one is in my router table on a rouseau lift. Got a lot of miles on it.
Thanks for the replys
-- Life is good.
View NiteWalker's profile
NiteWalker
2738 posts in 2816 days
#4 posted 10-17-2012 01:34 AM
Likely the speed controller.
It wouldn’t hurt to replace the brushes while you’re at it.
Come to think of it, try blowing it out with compressed air.
Also, there’s nothing wrong with using extension cords if you use a thick enough gauge. As an example, the only outlet in my shop is by the door; my workbench is on the other end of the shop. I never have more than two tools running and use a 25’ 12ga extension cord to power everything. No issues in 2+ years. I don’t want to upgrade the electrical because we’re renting.
View pintodeluxe's profile
pintodeluxe
5817 posts in 3052 days
#5 posted 10-17-2012 03:18 AM
Sounds like the armature assembly that controls the variable speed. I would talk with technical support at Makita.
View Joe Lyddon's profile
Joe Lyddon
10372 posts in 4291 days
#6 posted 10-17-2012 04:59 PM
Sounds like the potentiometer (armature) assembly that controls the variable speed. I would talk with technical support at Makita.
404 - Not Found
2544 posts in 3208 days
#7 posted 10-17-2012 07:22 PM
Had a similar problem with a Dewalt router, small magnet on top of the armature worked loose and lost all speed control. (This could be the ‘potentiometer’ as mentioned by JL).
NiteWalker
#8 posted 10-17-2012 11:31 PM
Renners, that magnetic ring breaking on the 618 is a known problem dewalt refuses to acknowledge.
Both of my 618’s did the same thing.
