Joinery For "slanted" sides
Forum topic by Farhad posted 10-16-2012 01:05 PM 1218 views 0 times favorited 2 replies Add to Favorites Watch
View Farhad's profile
Farhad
14 posts in 2098 days
10-16-2012 01:05 PM
Topic tags/keywords: joining
Hi, I wish to make a flower box with slanted sides using various mortise and tenon techniques. Can anyone help me please as to how I should go about it. I can’t work out all angles on the joints to make a perfect fit.Do I make sense to anyone?
-- Farhad
2 replies so far
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3122 days
#1 posted 10-16-2012 01:59 PM
How big? With smaller, shallow ones I’d probably make them with 2-by construction lumber and then saw the tapers later. For larger ones, I’m not sure why M&T comes into play unless the sides are rail/stile with floating panels? With solid panels I’d just use half-laps or tongue & groove.
If you did use rail and stile panels, then I be inclined to only use slanted sides for the lengths, keeping the shape of the planter more like a trough. That way, you aren’t dealing with compound cuts for the M&T on the ends and you could just cut the tenons first and shape the mortises later directly by dry fitting them together. Or, you could just use floating tenons.
Anyway, I thought I post to give this a good bump. Perhaps, a picture would help with what you are trying to do?
-- jay, www.allaboutastro.com
Farhad
#2 posted 10-23-2012 03:42 PM
Thanks a lot J for taking time. It’s a good feeling to find people care . Ur answer wasn’t what I was looking for but it did make me think a lot. Guess found the way. Maybe i’ll post after I finished building it.
-- Farhad
