sled
Forum topic by Bsmoot posted 10-16-2012 12:29 AM 833 views 0 times favorited 3 replies Add to Favorites Watch
View Bsmoot's profile
Bsmoot
64 posts in 2969 days
10-16-2012 12:29 AM
When I make my cut on my tablesaw sled how high does blade need to be 1/2” 1/4”
-- Bryant north carolina
3 replies so far
View jeff's profile
jeff
1081 posts in 3492 days
#1 posted 10-18-2012 09:27 AM
the post is a few days old and maybe you found the answer but,i would assume just above your material,or have the gullets of the blade just above your material.
-- Jeff,Tucson,Az.
View flskipper's profile
flskipper
24 posts in 3722 days
#2 posted 10-18-2012 11:09 AM
The same as for cutting without the sled, with the gullets of the saw blade just above the material being cut.
View Charlie's profile
Charlie
1100 posts in 2313 days
#3 posted 10-18-2012 11:16 AM
Interestingly, my Freud blades have instructions to position them so that 1/2 of a TOOTH is above the work. So basically half the gullet is exposed, not the whole gullet. If you do like the instructions say, you get super clean edges top and bottom, too high or too low and you start to see tear out top or bottom depending on if you’re high or low.
Other than that, I’ve always used the “expose the gullet” method.
