Outdoor Finish Question
Forum topic by Max posted 116 days ago 216 views 0 times favorited 11 replies Add to Favorites
View Max's profile
Max
6569 posts in 810 days
116 days ago
Topic tags/keywords: redwood finish outdoors chair adirondack water proof question
I am in the process of completing a couple of Adirondack chairs. These are being made with some reclaimed heart redwood from Train tunnels and bridges. The wood is around 100 yrs old and, as you would suspect, very dry.
My questions is what would be the best finish for these chairs for outdoor use? What about those water seal products like Thompson’s water seal? I would like some thing that will not cover the nice color and grain of these chairs, yet provide great protection. Any suggestions would be very much appreciated. Thank you in advance.
13585 posts in 937 days
116 days ago
Try to find some penofin finish. They are on the web. They make a Marine finish that is 99.44% uv block but it is a “Clear finish”
They use it for log homes etc.
You might aslso try some spar varnish. I think that it is a marine varnish.
View drgoodharp's profile
drgoodharp
122 posts in 664 days
116 days ago
Hi Max:
Stay away from Thompson’s Water Seal. It is strictly a consumer product.
Look at a good Spar or Marine Varnishes. I like Zar exterior varnishes.
Also, Cetol from Sikkens is an excellent finish for outdoor redwood and cedar.
-- Randy (P), rustic wood crafts, Morning View, Kentucky
View tenontim's profile
tenontim
960 posts in 281 days
116 days ago
I’m a big fan of pure tung oil. I protects and doesn’t put a film on the wood, that later you will have to sand off and redo. The tung oil will give the wood a natural look and has a nice feel to it. You can add another coat anytime without really any prep work. I would start out with about 8-10 coats over as many days.
-- Tim -- http://tmuli.com
View John Gray's profile
John Gray
883 posts in 422 days
116 days ago
I used a Tung oil finish (Tung oil and paint thinner? purchased from Rockler no longer available anywhere) when I stripped the varnish from the arms of my patio chairs and it has worked great. Any time I have used UV protected Spar Varnish on any outdoor wood it has really deteriotated after a year or two, turned brown/black and was ugly. I put on the Tung Oil Formula on with at least 10 coats, you should reapply each year.
View CedarFreakCarl's profile
CedarFreakCarl
400 posts in 590 days
116 days ago
Down here in the sunny south, just about any surface built film type of finish whether it’s got uv protection or not will crinkle up like corn flakes within a year or two. I agree with the last two posters in that a penetrating type of finish will work better in the long run even if you have to re apply every year. Tung oil is great as well as Cabot’s Timber Oil or some other similar product. Watco makes a pretty good outdoor finish too.
-- Carl Rast, Pelion, SC
View Max's profile
Max
116 days ago
Sounds like so far the Tung Oil, or Oil finish is the most popular. Any other suggestions. I checked out the penifon finish that Karson mentioned and it looks to be an oil finish also. Keep them coming.
View trifern's profile
trifern
4969 posts in 304 days
116 days ago
Cabot does make some really nice products for wood being used outdoors. The timber oil is probably your best bet from their product line up.
View Dominic Vanacora's profile
Dominic Vanacora
449 posts in 406 days
116 days ago
I’m a rookie like you but I made a small no back chair for the ailing wife. (A place for her to rest) It was make of store purchased (home depot) cedar. Well it took longer to make than I would have expected but don’t they all. I finished it in spar varnish By Zar. We have all finished wood before what’s the big deal, Well I live in Florida, (miid state) and this is summer and it rains every few days.
I finished it and let it dry, and it took Four days to dry in the Sun. It looked great, like I should be selling it. I leave it outside for two days and mildew starting to form all over the chair. Well the wife comes in and states I can’t sit on that it has mildew all over it. Of course she doesn’t care about the 20 maybe 30 hours in the 90 degree heat in the gararge over 4 days. Well to make a long story short I later read that Spar varnishes require 8, that right it said 8 coats. I have refinished it yet, I just wiped it down with pool chlorine that worked but its still stained. I not sure what to do now except sand it all down and start over.
-- Dominic, Trinity, Florida...Lets be safe out there.
View Gofor's profile
Gofor
73 posts in 324 days
116 days ago
I used General Finishes Outdoor Oil on a rocking chair that sits on my deck here in NC (we have 100 degrees several times a year and high humidity also). It holds up fairly well in the shade (I redo it annually). Like Dominic, I have a mildew problem, but found that Lysol Sanitizing Wipes takes the mildew right off, even if I let it accumulate for several months.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
View John's profile
John
19 posts in 120 days
116 days ago
I used Watco teak oil on some meratni deck furniture I recently made. Three coats over two days and after 4 – 6 weeks out on the deck in the sun one additional coat applied quickly with a sponge. Seems to me to be the way to go. No surface film but penetrates the wood well and imparts a nice rich color to the wood. The meranti looks similar to the jatoba used by the LJ who posted the nice slatted deck table with the tapered legs. I also used the teak oil on a cedar table top. We do get lots of sun, heat and high humidity here on the south shore of Long Island. I used it on an outdoor table top last season and left the table out all winter but had to do a quick sanding this spring to get all the weathered grey off. Leaving the furniture out all winter is not the way to go unless I can keep the sun off it.
-- John, Long Island, NY
View Douglas Bordner's profile (online now)
Douglas Bordner
2732 posts in 600 days
116 days ago
Sean Clarke, a frequent Fine Woodworking author and professional finisher uses “… Smith & Company’s MultiWoodPrime (also called Clear Penetrating Epoxy Sealer), is a two-part resin epoxy that penetrates the wood, making it resistant to fungi and water damage. It also chemically bonds to the Epifanes varnish, which has ultraviolet (UV) inhibitors to protect the wood for years to come.”
quoted from FWW.com
Bookmark And Share This Page
