| Forum topic by thumbs | posted 567 days ago | 893 views | 0 times favorited | 19 replies | ![]() |
567 days ago |
Am just getting into spraying and am going to make a small spray booth in shop. Am looking for a source for a reasonably priced exhaust fan and also any tips on designing and setting the booth up and anything else that might help. Have ordered an HVLP sprayer and need to get ready to use it. -- Mitakuya Oyasin |
567 days ago |
I used an old stove exhaust fan. Because it was near grease it had to be spark free. -- No piece is cut too short. It was meant for a smaller project. |
567 days ago |
DAGS on “build portable spray booth” and you’ll find a wealth of information. Pay close attention to proper air movement, and check with your local building codes for proper venting (Venting directly through a window may be a no-no in your area as an example) A lot will depend on what you’re spraying. -- Nicky |
566 days ago |
Thanks for the reply. I am relatively new to this and don’t know how to find source you mention in your post. Would appreciate your further assistance in telling me how to access it. -- Mitakuya Oyasin |
566 days ago |
I am guessing that DAGS means – do a Google search on the phrase “build portable spray booth”. -- Bill, Turlock California, http://www.brookswoodworks.com |
566 days ago |
You might want to check with a local furnace contractor in your area. I used a furnace blower motor and “squirrel cage” fan out of a furnace that was replaced with a newer one by the contractor. They often just toss them, and you can get one for nothing. I put it in a box as an air filtration system. (See my projects for pics). I think this concept might adapt well as an exhaust system as it can move a lot of air quietly. -- Accuracy is not in your power tool, it's in you |
566 days ago |
Thanks for those safety tips SST. -- John |
566 days ago |
SST, -- Mitakuya Oyasin |
565 days ago |
After I wrote about using a furnace fan, I went & looked at my filter unit and maybe there’s no way to get the motor shielded, since it sits in the middle of the fan. I have seen these squirrel cage fans that don’t surround the motor and are operated by a v-belt. Maybe one of those could be adapted to an extended motor shaft that runs through a grommeted hole in a motor enclosure box. Another thing about exhausting a spray booth, is to draw the air through a fairly porous (cheap) furnace filter, or maybe 2 successive filters to get most of the air born material out before you run it through the ducts and past the fan. These will fill up fast, so the pricey filters with the really small pores will plug too fast. The filter should be right at the booth/exit duct interface so the ducts stay as clean as possible. We used special auto spray booth filters. Maybe an auto paint supplier has them.-SST -- Accuracy is not in your power tool, it's in you |
565 days ago |
This is a great story to keep going. I bet a lot of us would like a spray booth of some kind, so it is nice to hear of someone building one. Have you decided on the size of it yet? -- Bill, Turlock California, http://www.brookswoodworks.com |
565 days ago |
I’d kiss a monkey just to have the space for a spray booth:-)) -- Bill - "Suit yourself and let the rest be pleased." http://www.cajunpen.com/ |
565 days ago |
What I’m doing isn’t original, but I thnk it will work. Was a hint I saw somewhere. I have some heavy mil plastic and will cut my sides to width and cut the length long. Then fasten to ceiling. Fasten some type of solid (PVC, wood strip, etc) the length of each side on bottom of each side. Use velcro tape on edge to fasten sides together when using booth. I don’t think it would be necessary to use a solid strip, just short pieces. On ceiling put velco strip near top of each side near ends. Then just roll the sides up and fasten w/velcro strip on ceiling and they are out of the way, ready to drop down and make a booth. Hopefully this works, justy a theory now. -- Mitakuya Oyasin |
565 days ago |
It seems that if you use non rigid walls you will not be able to have much air movement because of a “balloon effect”. It also occurred to me as I’m remembering the auto spray booths we had, in addition to the vent van removing air, we had an intake fan to balance the air flow. On a small scale, you might not need both, but if you only used one fan setup and it was to push in the air, you could mount it just outside the booth, and since the air flow was away from the fan, you might not have to shield the motor. (unless, of course, you shut it off and then restart it while the booth is full of fumes/vapors/exploding stuff, some drifts back, and then you blow yourself into the next county. -- Accuracy is not in your power tool, it's in you |
565 days ago |
Lots of good advice and thiings to think about. It’s actually starting to sound like we might come up w/something. What about a furnace fan or actually any type, mounted high and outside of booth, w/a filter in front of it, to push air in and a closable vent on opposite side mounted low exhausting to the outside. -- Mitakuya Oyasin |
562 days ago |
there was an article on making a booth in the last issue of Canadian Woodworking. -- "Functional WoodArt" by Debbie, Canada (http://www.execulink.com/~yohan) |
562 days ago |
What did they come up with Debbie? I do not recall ever seeing a Canadian Woodworking magazine in these parts… -- Bill, Turlock California, http://www.brookswoodworks.com |
562 days ago |
I’ve never seen one in a book store down here either. I did find their web site. http://www.canadianwoodworking.com/-- We must guard our enthusiasm as we would our life - James Krenov |
561 days ago |
I found the magazine… June/July 2007 pg 24 4 pieces of “coreplast” (I think I know it as foamcore), duct-taped together (easy folding for storage) and sits on a larger piece as the base. It is taped in a way that allows the three sides to fold up. 1/4” ply for the back. Blocks are added in the corner of this with holes to slide dowels through and through the coreplast to stabilize it when it is put together. (plans uses cotter pins in the dowels to make sure they don’t slip out during use) A window is cut in the back, smaller than the size of fan to be used. A furnace filter is placed in front of the fan, which they have sitting on a wooden stand, at the right height for the window. The back panel can be bolted to the fan stand. that’s it. -- "Functional WoodArt" by Debbie, Canada (http://www.execulink.com/~yohan) |
561 days ago |
Thank you Debbie. Sounds practical and simple. It will be awhile before I get a chance to persue this, but defininitely sounds like it’s worth trying. Will put in a post when I have tried it. -- Mitakuya Oyasin |
560 days ago |
A picture would be nice to see, if one is available. But, this sounds like a good start for a spray booth. -- Bill, Turlock California, http://www.brookswoodworks.com |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1363 |
| Become a sponsor |
1809 |
| Become a sponsor |
124 |
| Become a sponsor |
379 |
| Become a sponsor |
111 |
| Become a sponsor |
Woodworking Trade & Swap
252 |
| Become a sponsor |
Coffee Lounge
1019 |
| Become a sponsor |
LumberJocks.com Site Feedback
286 |
