Education on Old Slot Screws and Slot Screw Drivers
« back to Hand Tools forum
Forum topic by hhhopks posted 10-15-2012 08:24 PM 683 views 0 times favorited 1 reply Add to Favorites Watch
View hhhopks's profile
hhhopks
650 posts in 2248 days
10-15-2012 08:24 PM
Topic tags/keywords: hand tools slot screw driver question
Am I just imagining it? The older screws often have thin slots such that modern standard screw driver wont’ work with it because it is too thick.
If I don’t have a matching older slot screw driver, it would seem that I would need to sharpen the tip to of my screw driver to get it to fit right.
Just need to be educated on the very basics.
-- I'll be a woodworker when I grow up. HHHOPKS
1 reply so far
View Nicky's profile
Nicky
695 posts in 3962 days
#1 posted 10-15-2012 08:38 PM
You should use a driver that fits the slot, both in length an thickness.
You can surly dress the blade to fit. If you’re using a grinder, don’t let it get to hot as it will lose it’s temper. Files/stones could also be used.
-- Nicky
