| Forum topic by randyc | posted 476 days ago | 630 views | 0 times favorited | 14 replies | ![]() |
476 days ago |
I’m relatively new to woodworking and have a question/problem regarding tapering on the table saw. I hope you can help. I built a tapering jig that I used to taper a 2” square coffee table leg down to 1 1/4”. What I’m finding is that the taper is uneven at the top end ( the thick end). By uneven I mean that the taper on one side of the piece starts 5/16” lower than on the other side. My analysis of the situation is that since the saw blade is circular, the blade enters the piece at table level before it enters the piece higher up. In my case, the blade enters the piece at table level but doesn’t get to the other edge which is 2” above the table until I’ve traveled 5/16”, and that’s the cause of the uneveness. Is my analysis right? Thanks for you help. -Randy |
476 days ago |
remember when you take a first cut you are no longer working with a square piece of wood. Hence when you put that newly cut face against the fence it will be off on the second cut by the ammount removed by the first cut. Watch for this as it throws your work out by quite a bit unless you use wedges to compensate ot reset the jig to compensate you will never remove evenly otherwise regards Alistair -- excuse my typing as I have a form of parkinsons disease |
476 days ago |
I guess I wasn’t clear in my description. I’ve only made one cut at this point. In other words, I set the jig to start the taper 5” from the end of the board. I make the cut, and then I rotate the board 90 deg. to take a look at the result. What is see is that the taper starts at 5” from the end on the left edge of the piece (exactly what I want), but as I look across the width of the board the taper starts lower and lower, eventally starting 5 5/16” from the end by the time I get to the right edge of the face. |
476 days ago |
When I use my tapering jig, I draw a line around the top end of the leg- where I want the tapers to start. Then I mark the bottom of the leg where I want the tapers to end. After making the first cut, I rotate the leg and check to see if the starting and ending points line up with the blade cutting path. If not, readjust the jig accordingly. Also, remember, the taper starts at the point where the saw blade and table (saw or jig surface) intersect. Lew |
476 days ago |
I think the problem may be that your saw blade and the face the taper is coming off of are tilted just slightly away from each other(vertically). Maybe your table leg is just slightly out of square, or the blade is just slightly off of 90 degrees. |
476 days ago |
I think that you might want to check your set up. The wood should be square to begin with and your saw blade set square at 90. These are the most common errors that come to my mind. Also, be sure nothing is shifting during the cut. Charles Neil just posted a tapering jig. That might also help. Also try a message to him. He is great. This is the link to his site: http://www.antiquesbuiltdaily.com/tips.htm -- Berta in NC |
476 days ago |
I taper my legs to be oversized by a 1/16” at least. I then joint all surfaces. Brings them down to where I want them and the finish is good. -- Bruce from Central New York |
476 days ago |
Randy, I’ve experienced the same problem. Honestly, all I do is sand the face smooth and “blend” that area. It’s not noticable, unless someone is looking for it. With that said, if our fellow LJ’s have solutions, I’d love to learn. -- Randy, Tupelo, MS ~ May I become more like the Master Carpenter every day. |
475 days ago |
Hi Randy I think that it’s normal because the blade is round. It would not happen on a band saw… To visualize it, I took these 3 pictures…..sorry, I could not make a “live show” because it’s 11:20 PM here and I don’t think that my wife nor the neighbors would like it…. :-) That’s a view from above…as you can see, the teeth that are close to the table will start to cut the lower part of the board but, the upper part will “delay” till the upper teeth will start to bite. And, the bigger the angle, the bigger the “delay” As randy Sharp said…sanding….or planing Regards |
475 days ago |
As long as the blade is perfectly vertical, the side of the board is perfectly vertical, and the feed direction is parallel to the blade, the taper should be even. The blade being round does not cause it to be uneven because if it did you’d never be able to cut anything square! A bandsaw would have the same problem if it was tilted just slightly to one side, or if the board was just slightly out of square. |
475 days ago |
You answered your own question: “My analysis of the situation is that since the saw blade is circular, the blade enters the piece at table level before it enters the piece higher up.” This happens to me every time I taper on a TS. What I sometimes do is take the leg to the jointer and face joint the tapered sides. Problem is gone. OR sand it until it blends in as others mentioned. Another option is to use a bandsaw, but ‘I’ am always happier with the result I get at the TS when tapering. Good Luck. -- Brian http://www.garagewoodworks.com |
475 days ago |
Ben, When the OP states ”uneven” I don’t think he means unsquare. The round blade is what causes this problem. -- Brian http://www.garagewoodworks.com |
475 days ago |
I’m afraid I must still respectfully disagree. I understood that he meant the taper started a little lower on one side, but I don’t think the round saw blade is to blame. If you sight down your table saw from front to back, the blade appears as a straight vertical line. This is what the wood “sees” as it is fed into the blade, unless the wood or the blade moves sideways. The blade cuts the bottom part first, but as the cut climbs, it climbs straight up (assuming the blade is at 90 degrees, the board edge is at 90 degrees, and the board is moving in a direction parallel to the blade). |
475 days ago |
It seems to me that all componets must be at 90 degrees to the blade. I agree with Ben, if you sight down the table top the blade is veritcal just like the band saw blade. -- Bill - If I knew GRANDKIDS were so much fun I would have had them first. |
475 days ago |
Thank you all for the responses. I’m overwhelmed by the attention you’ve given to my little problem. I’m looking forward to my new relationship with all of you lumberjocks. Hopefully the day when I can actually give some advice rather than just be on the receiveing end won’t be too far off. -Randy |
| Forum | Topics |
Woodworking Skill Share
2916 |
3942 |
256 |
949 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2385 |
LumberJocks.com Site Feedback
524 |
