1/16" bandsaw blade?
Forum topic by Cole Tallerman posted 10-15-2012 02:33 AM 2654 views 0 times favorited 8 replies Add to Favorites Watch
View Cole Tallerman's profile
Cole Tallerman
392 posts in 2207 days
10-15-2012 02:33 AM
I was watching a video on fine woodworking and the guy mentioned that he had a 1/16” blade! any idea of where i can get one for my 14” bandsaw? Ive never seen them before
8 replies so far
View Granddaddy1's profile
Granddaddy1
182 posts in 2224 days
#1 posted 10-15-2012 06:56 PM
Never seen one. If you did find it, I’d think it would snap the first use. A 1/16” weld at the joint wouldn’t hold much.
-- Ron Wilson - maker of fine firewood!
View Wildwood's profile
Wildwood
2322 posts in 2157 days
#2 posted 10-15-2012 07:33 PM
Always thought 1/8”, 3/16” and ¼” blades smallest blades could use on a 14” bandsaw. Never seen 1/16” blades for a 14” BS, doesn’t mean not out there. Know they have them for sale for smaller bandsaws.
Nice video:
https://www.youtube.com/watch?v=mq4UmoTKPwY
-- Bill
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3137 days
#3 posted 10-15-2012 08:19 PM
granddaddy
two things that make it possible .. is that he is making a scarfed joint on the flatside of the blade
and he don´t weld it but use silverbrace tread that melt around 620 degree celcius
its maybee not as strong as welding but its not fragile as a welded joint in witch case
is a benefit since it can bend a little bit compared to a welded joint
Dennis
View HorizontalMike's profile
HorizontalMike
7758 posts in 2936 days
#4 posted 10-15-2012 10:00 PM
”... had a 1/16” blade!...”
They call them ”SCROLL SAWS”
View Bill White's profile
Bill White
4948 posts in 3983 days
#5 posted 10-15-2012 10:19 PM
Had one for my old 11” Magna with Cool Blocks. Ya gotta have guides that cover the blade. Bearings just won’t work on a blade that small.
Bill
-- bill@magraphics.us
View lab7654's profile
lab7654
266 posts in 2269 days
#6 posted 10-15-2012 10:23 PM
The narrowest I’ve used is 1/8” 10 TPI, and that seemed plenty “nimble”. I broke it after two uses, but that was my fault. Even though Timberwolf sent me a replacement, I bought a 3/16” 4 TPI and use that much more. A 1/16” blade wouldn’t have any more capacity than a scroll saw, since it would have a lot of teeth per inch and would overheat on any stock thicker than what a scroll saw can take anyway.
-- Tristin King -- When in doubt, sand it.
Cole Tallerman
#7 posted 10-16-2012 03:01 AM
here is the video that i found it on: http://www.finewoodworking.com/item/57011/basic-box-making
Wildwood
#8 posted 10-16-2012 10:57 AM
Would not want a 1/16” blade for making those kinds of boxes shown in fine woodworking video. Normal 3/8” or ½” blade should work fine.
This video talks about 1/8” blades but tells you ¼” will work fine for his style of boxes.
http://woodtube.ning.com/video/how-to-make-bandsaw-boxes
Already been mention 3/16” blade on a 14” band saw about smallest can go for most people. JMHO, cool blocks work better than bearing blade guides using blades less than ¼”.
Finding a 3/16” & ¼” blade with right TPI and tooth set for cutting boxes shown in the video posted above kind of a compromise when goal is reduce amount of sanding and not taking all day to make cuts.
-- Bill
