Cutting Board Groove
Forum topic by Rayban posted 10-14-2012 02:03 AM 4439 views 2 times favorited 12 replies Add to Favorites Watch
View Rayban's profile
Rayban
3 posts in 2366 days
10-14-2012 02:03 AM
I am making cutting boards for Christmas presents and would like to cut a groove around the perimeter to keep liquids from running off the board. How is the best way to cut those? I thought about using a router with a round bit but I don’t know how to keep it steady and a uniform distance from the edge of the board. Thanks.
12 replies so far
View longgone's profile
longgone
5688 posts in 3426 days
#1 posted 10-14-2012 02:13 AM
I would use a router table. i do not make cutting boards but this would seem to be a logical method. there are a lot of cutting board builders on lumberjocks that will have the tried and true suggested methods.
View D_Allen's profile
D_Allen
495 posts in 2902 days
#2 posted 10-14-2012 02:23 AM
I used a template and a bearing guide round bit. The template was sized to put the juice groove where I wanted it by making it the shape of the board only smaller. The bit rode on the outer edge of the guide which was attached with double faced tape. Multiple passes are recommended and some sanding may be necessary.
-- Website is finally up and running....www.woodandwrite.com
View JesseTutt's profile
JesseTutt
854 posts in 2228 days
#3 posted 10-14-2012 04:24 AM
I agree with D_Allen, make a template and use a pattern bit. Your template does not necessary have to follow the same shape as the outside of the cutting board. You cutting board could have square sides and your pattern for groove could have rounded corners.
View waho6o9's profile
waho6o9
8360 posts in 2695 days
#4 posted 10-14-2012 04:43 AM
Templates are a great way as well.
I marked the lines, set up the guide, and plunged away, easy peasy.
View Dusty56's profile
Dusty56
11822 posts in 3806 days
#5 posted 10-14-2012 04:49 AM
A template would be easiest if you only make one size board.
I use a router edge guide because I make all different sizes of boards.
I used to use my 690 PC router but since I got my Bosch Colt , it is much easier to handle and a lot less strain. Multiple passes are the key along with a new or very sharp round nosed bit.
Variable speed motor will help you to prevent burns when you slow down the feed rate coming into the corners. Practice many times on scrap wood before cutting into your project board , especially joining the corners of the groove. Stop when the groove looks good to you. It doesn’t have to be any specified depth.
And this ugly duckling I made with a juice “well” that the grooves drain in to : )
View grenger's profile
grenger
199 posts in 3484 days
#6 posted 01-27-2013 05:37 PM
I just tried this technique, not bad
https://www.youtube.com/watch?feature=player_detailpage&v=lFcbrn7Ebmw
-- Gerry (the beginner), Gatineau, QC, Canada
Dusty56
#7 posted 01-27-2013 05:59 PM
Thanks for the link.
I knew he was going to end up with burn marks in the corners with that process though.
It was a good video and I’m sure the process can be used for other reasons as well : )
How did your corners come out ?
grenger
#8 posted 01-27-2013 07:51 PM
I did a quick setup and actually my corners are not bad…. did a first tryout on a piece of pine…. sanding the corners came out not bad.
not as nice as yours.
Dusty56
#9 posted 01-28-2013 02:02 AM
Practice , practice , practice…..wait until you try some hardwood scraps before proceeding with your real project …
and thank you for my corners compliment : )
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2472 days
#10 posted 01-28-2013 02:22 AM
I always thought it was done with a router guide fence attached to the router, could be templated out as well.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
Dusty56
#11 posted 01-28-2013 03:16 AM
“a router guide fence attached to the router”
That’s what I use on my boards.
grenger
#12 posted 02-24-2013 12:21 PM
an other way of doing juice grooves. Eeasier to go around corners when the corners of the template and rounded off
