| Forum topic by thedude50 | posted 222 days ago | 1605 views | 0 times favorited | 39 replies | ![]() |
222 days ago |
I just got a new bench grinder A Porter Cable 8 inch with a lamp and variable speed it is a slow grinder and works very well. Of coarse I removed all the guards as i wanted to use my One Way Wolverine Jig on it. The grinders base was so high I didn’t have to use the 1/2 inch riser block for the grinder like i did for my old 6 inch grinder. I mounted the tool locks centered under the wheels and was very happy with how straight they are. I then went to set up the tool rest for the regular tools. it is the flat square tool rest it is nice and wide and very stable. This is when it hit me How do I set this up for 25 degrees. I simply took a chisel I have that is new and has a known 25 degree bevel on it and aligned it to the wheel. that got me to thinking and I dont have an answer for this one on the top of my head but how do you set up a tool rest for bevels you dont have a reference for to get say an accurate 27 or 35 degree bevel on. Say I want to regrind some chisels to this new bevel for pounding out mortises or some other reason. I figured a set up block would work but what is the best way to get an accurate bevel to use as a reference for setting up the grinder. ALL HELP IS APPRECIATED. thanks Lance -- when I am not on Lumberjocks I am on @ http://thisoldworkshop.com where we allow free speech |
39 replies so far
#1 posted 221 days ago |
Use a Wixie box to set the table angle!! -- Jim Jakosh.....Practical Wood Products...........Learn something new every day!! |
#2 posted 221 days ago |
I tried that it does not work because the wheel is an angle while I thought it would be fine it was off by miles -- when I am not on Lumberjocks I am on @ http://thisoldworkshop.com where we allow free speech |
#3 posted 221 days ago |
Basically the left indicator is the diameter of the wheel and the Except you need the indicators reversed if I understand the |
#4 posted 221 days ago |
Yes as you are trying to adjust the grinder to the tool rest so you can not simply place the table at 25 degrees the bevel wont be the same because of the wheel Geometry. I discussed this with my wife she is a geometry teacher and said she can figure this out but that some poor woodworking math wiz most likely has already figured this out so I went back to the search engines thank god for Google There I found this link after many hours of searching different phrases. Here is the best answer I have found I will be making these jigs on Monday as I am Off to Pasadena in the morning for the wood show So Many tools so little time the trip should be great but I am on a tight budget as the state is screwing me again. So if you like me and you want to get good results off your bench grinder so you can go from bench grinder to tormek to Whetstones or how ever you get a razor edge this is the key to setting up your grinder the right way. Click Here for the PDF to cure this Problem -- when I am not on Lumberjocks I am on @ http://thisoldworkshop.com where we allow free speech |
#5 posted 221 days ago |
http://www.harborfreight.com/dial-gauge-angle-finder-34214.html These angle finders with magnetic base will get you close. Can pay a little or lot guess they all about the same. -- Bill |
#6 posted 221 days ago |
Because you’re grinding on the tangent of the wheel, the tool rest needs to be set differently for the thickness of each tool. I make grinding templates the same thickness of each of the tools I grind. These are about 3/4” wide and 6” long. I cut a 25º bevel on one end and a 30º bevel on the other. The tool rest is set by eye so that the wheel contacts the bevel of the template, using the desired angle, in the center. If you set the tool rest for a 3/16” thick tool and grind a 1/8” thick tool your bevel will be more obtuse than desired. If the rest is set for that same 3/16” tool and you grind a 1/4” tool the bevel will be more acute than desired. The grinding templates I make are the easiest way I’ve found to deal with grinding on the tangent of a wheel. Angle finders just don’t work on grinders. |
#7 posted 221 days ago |
Lance, The pdf you provided seems to be a decent method, however, it may not work equally well for all users. It seems that some of the newer grinders have less and less of the actual wheel exposed thus not allowing a longer stick to be effectively used. The pdf does mention this though. In addition, the grinder table that comes with your Wolverine jig sits even higher, further limiting the use of this kind of jig.
They also do not address the issue of wheel wear affecting its use. That should be considered. After thinking about this a little more, realize that the thickness of the blade being sharpened will have an effect on the Bevel Angle as defined in Figure 1 in the pdf. In other words, to get a 25 degree angle on a thin blade will require a different grinder-table angle than when sharpening a thick blade of the same angle. SketchUp, SketchUp, SketchUp… From my calculations(which could easily be wrong), using a new 8” wheel, the table setting for an 1/8” thick blade is 2.3 degrees different than for grinding a 1/4” thick blade. From this, I would say that the method in the pdf is in error. Actually this error would be inherent with many other gauges commonly sold. Do any of the gauges take the thickness of the blade being sharpened into consideration? Hmmmmmmm. But in all reality, unless you switch from grinder to grinder, 2.3 degrees may be a moot point. The biggest effect I could see is possibly grinding off more material than necessary, thus slightly shortening the life of the tool. Edit: I see that while typing, lwllms has pointed out the same issue with the thickness. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#8 posted 220 days ago |
Ok guys I will send that information to the math guy that came ofp with the grinding templates so he can rebut this or confirm it . On the size of the wheel I think he did address it at the beginning or on the web page I got that linked to the Pdf I posted. I will check on this. My desire is to get an accurate grind on my planer blades that when I take them to the Tormek I am not regrinding a new bevel rather I want to be smoothing the bevel I already ground and I want it to be the same as the accurate bevel I got from the Tormek. Also I want to build an accurate set up block to hone my bevels with a honing guide. On most of my work I do this freehand but there are times when free hand is not the best way like when doing the Iron for my Shoulder planes trying to hold those little suckers straight is a bear I would give in and use the honing guide if I knew my set up was dead on accurate to my Tormek. I want to thank you all for your help solving these issues once we do. I think A blog is in order to teach everyone the methods we figure out together so others don’t have to struggle with Geometry and can get accurate repeatable results on their grinders. Have any of you guys used the Tormek Grinder jig and if so does it address these issues? I am not married to the ONE Way jig and I can afford the Tormek Jig and if it does address these issues. I could be sold very easily. -- when I am not on Lumberjocks I am on @ http://thisoldworkshop.com where we allow free speech |
#9 posted 220 days ago |
Lance, I stand corrected. I went back and read more of the pdf(rather than just looking at the pictures). He in fact admits to the thickness affecting the accuracy. He also mentions referring to graphs which are included in Hollow Ground Geometry to determine the necessary angle corrections. I think it is kind of odd that having seen many of these type of angle jigs, this is the first time I’ve ever heard of the need for corrections due to blade thickness. Interesting. I’m glad you posted this. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#10 posted 220 days ago |
Dude thanks for bringing this up another new for me :-) Dennis |
#11 posted 220 days ago |
Lance, I’m not much into this… BUT… will this work? Take, say a piece of 1×2 at a good length… At one end, using a protractor, draw and cut the desired angle at an Endpoint. Lay the board on your adjustable grinding table & move your table around at the various angles until you can get your Wooden Angle against your grinding wheel flush & tighten it. Place your tool onto your table (like the wood was) and grind your angle. Does that make sense? -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#12 posted 220 days ago |
I cut 1/2” – 3’4” thick scrap sticks to the various angles I want to grind. Next, I make a mark on the end of the stick, distanced from the bottom edge equal to approximately half of the thickness of the tool I want to grind. The mark is KEY, the angle is not enough. These sticks are slid up to the wheel with the mark touching the wheel and I adjust the rest to match the stick. Lee Valley sells a setup block that work exactly the same way, included with the Veritas rest but apparently not available alone. Scroll down to VERITAS ANGLE SETTING GAUGE My sticks have one angle at each end. Five degree increments from 20-55 degrees, and a 27, took about 10 minutes to make. They work GREAT, account for wheel wear, and angles are easily repeatable. -- It's all good, if it's wood... |
#13 posted 220 days ago |
Very interesting post , dude. Thank you : ) -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
#14 posted 220 days ago |
This makes my head hurt. -- bill@magraphics.us |
#15 posted 220 days ago |
+1 to Bill. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15791 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
