How Much can a blade affect a miter cut.
Forum topic by Rookie702 posted 10-11-2012 05:31 PM 1396 views 0 times favorited 20 replies Add to Favorites Watch
View Rookie702's profile
Rookie702
43 posts in 2154 days
10-11-2012 05:31 PM
I’ve been trying to cut some 45 degree miters for some boxes i’m making for a girlfriend, and i’m having a hell of a time getting a straight miter.
How much effect will a dull blade have on the miter cut. I’m using maple so the wood is pretty hard. and it seems like like i get a bow in the miter when looking at it from its edge. These miters are 4-6 long. I tried some cedar, and it seems like these came out much straighter, was this because the wood is softer.
Can anyone recommend a quality blade, how many teeth?
20 replies so far
View MonteCristo's profile
MonteCristo
2099 posts in 2065 days
#1 posted 10-11-2012 05:55 PM
If the blade is dull, it should burn the maple while cutting, plus be hard to pull thru the maple. I am wondering if there is some slop in the saw carriage for you to be getting such a cut. Have you tested to be sure it’s not an optical illusion ?
A dull blade will also cause chipout, especially at the ends of the cut.
13594 posts in 3218 days
#2 posted 10-11-2012 06:02 PM
clean and sharp
is what works best
and stops or clamps
to keep the wood from ‘creeping’
i never use thin kerf blades
for just this reason
i know some like them
but to me they are just a marketing ploy
to use less steel
and jack the price
for ‘new and improved’
View knotscott's profile
knotscott
7822 posts in 3252 days
#3 posted 10-11-2012 06:05 PM
A high quality sharp blade that’s appropriate for the task is critical. Are you using a miter saw or a table saw?
Let us know what saw you’re using, and I’m sure someone can give you a good blade suggestion.
Rookie702
#4 posted 10-11-2012 06:06 PM
I was just reading a forum topic on clean blades, and i can honestly i have never cleaned a blade in my life, guess i’ll start tonight. I only woodwork as a hobby so my table saw and blades dont get that much use, just a couple of times of week so i think my blades are dirty and but still sharp.
View crank49's profile
crank49
4028 posts in 2848 days
#5 posted 10-11-2012 06:07 PM
Another important effect is whether there is damage to the blade.
If, for instance one edge clipped a hidden nail or staple and got chipped at some time in the past.
This will make the blade try to cut at an angle, but the bearings and shaft are fighting to keep it straight.
The result is some interesting warpage in the blade in the cut; might even look like a wave pattern.
View Grandpa's profile
Grandpa
3259 posts in 2552 days
#6 posted 10-11-2012 06:13 PM
A blade that is designed for a miter saw is critical. I loaned my saw to a friend. When it came home it had a different blade on it. It was recently sharpened and all but it was not a saw blade for that kind of work and you could not make two 45 deg cuts come together and close up or enven make a 90 degree angle. A new blade took care of that.
Rookie702
#7 posted 10-11-2012 06:29 PM
I’m using a JET 10” Contractor Saw, just purchased in May of this year, and i’ve setup the saw as best as i know how, plus have incra miter gauge.
knotscott
#8 posted 10-11-2012 07:22 PM
If cleaning your current blade doesn’t help, or if the current blade isnt’ a high quality blade, I’d definitely look to a new one. Considering the task, I’d opt for a full kerf blade to reduce the chance of deflection (though I do think a high quality thin kerf blade for many TS operations are fine).
Without knowing your blade budget, I’ll start with some bargains….the Delta 35-7657 40T ATB general purpose blade is still on sale through Cripe or Amazon for < $30 shipped. This German made Onsrud 50T blade is ~ $25 shipped. For ~ $70, the Infinity Combomax is the best of the 50T blades I’ve used. Nearly any high quality 40T to 60T 1/8” full kerf blade should do well if it’s suitable for TS.
Rookie702
#9 posted 10-11-2012 08:09 PM
Budget. what’s that?, when it comes to tools and hobbies for me if i want it and need it i pretty much get it. The mortgage company can wait. Haha…as far as blades, i’ve purchased 10 or 11 blades thinking they were all dull, i’m so excited to get home and clean my blades and hopefully they work again.
whoohoo
#10 posted 10-11-2012 08:22 PM
read up on the different blade types
they all have different purposes
designed for different tools and cuts
View Sgt374's profile
Sgt374
36 posts in 2471 days
#11 posted 10-11-2012 09:47 PM
What usually happens is the blade is dull and the maple is hard so you force the saw through the cut and the blade deflects and the wood pushes to the side giving you a bad cut. That’s why a sharp, clean, crosscut blade is necessary.
Rookie702
#12 posted 10-11-2012 09:58 PM
I have sandpaper against my fence and i can’t see it move or feel it move, but it sounds like the wood still is moving without me noticing is that correct?
knotscott
#13 posted 10-11-2012 10:35 PM
A dirty blades acts like a dull blade, and actually causes premature dulling. Definitely keep them clean!
It’s possible that your blade is actually deflecting during the cut. There are few things that can cause that. We know you’re using a Jet contractor saw, but not what blade you’ve been using.
View mrg's profile
mrg
793 posts in 2876 days
#14 posted 10-11-2012 10:41 PM
Is the blade adjusted high enough? If the blade is not high enough you will get a dished cut.
-- mrg
Rookie702
#15 posted 10-11-2012 11:06 PM
Is the blade adjusted high enough? If the blade is not high enough you will get a dished cut., ummm this might be the cause of some of my problems, as i was trying to keep the blade as low as possible in an effort to minimize any kind of deflection. Your term “dished” made sense to me and after thinking about the blade etc, this could be the case..thank you.
