3/4" Baltic Birch defect, how to minimize
Forum topic by jkjames posted 252 days ago 398 views 0 times favorited 6 replies Add to Favorites Watch
View jkjames's profile
jkjames
9 posts in 604 days
252 days ago
I have cut 3/4 Baltic Birch for a cabinet project and now at the finishing stage I have noticed a uniform wavy defect in the material. It is perpendicular to the grain, uniform in spacing at about 1”, seems to be a machine made “anomaly”. The waviness is visual… there is no waviness in the thickness of the panel.
I did go back and inspect the scraps and I can see the identical pattern in the raw stock, so my work on the wood didn’t cause the defect.
So now that my stain has accentuated the defect, I am pondering what to do to save the material. Anyone been here before??
The picture should give you an idea what it looks like, though it doesn’t truly show the prominence of the defect due to light and reflection, but you get the idea. It is across 100% of the panel.
View Loren's profile
5034 posts in 1846 days
#1 posted 252 days ago
Use a cabinet or card scraper to scrape it at about a 45 degree
angle to the grain in the panel, both ways. This will knock off
the high spots.
jkjames
9 posts in 604 days
#2 posted 252 days ago
The flatness of the outer ply is perfect. No high spots. I am wondering if the waviness is on an internal ply that may be showing through a non-100% opaque outer ply.
View Charlie's profile (online now)
Charlie
750 posts in 484 days
#3 posted 252 days ago
more likely they’re machine marks. Rollers under pressure can compress the fibers so they take stain differently.
View HorizontalMike's profile
HorizontalMike
5672 posts in 1112 days
#4 posted 252 days ago
I think Charlie is correct about the machine marks flattening the grain. With so little to work with on veneered ply, one has to wonder it it would be advisable to raise the grain with water and re-sand the finish. A dangerous prospect for sure.
The only thing I could think of, for the future, would be to use a wood pre-conditioner before staining, however that does not help here. Sorry.
View MrRon's profile
MrRon
1635 posts in 1441 days
#5 posted 252 days ago
Was this genuine Baltic Birch ply that comes in 5’x5’ sheets? If you cut from 4’x8’ panels, then that wasn’t BB and there would be more defects.
jkjames
9 posts in 604 days
#6 posted 252 days ago
MrRon,
It was 5×5 sheet BB/CP claimed by the lumber yard. No patches on either side of the sheet.
