| Forum topic by Cole Tallerman | posted 222 days ago | 640 views | 0 times favorited | 6 replies | ![]() |
222 days ago |
I think its called runout? Well anyway, my drill press arbor doesn’t spin perfectly straight. I have a huge old craftsman drill press. I realized this after trying to build my jointer and it wasn’t precise enough. So my question is, would it be cheaper to have a machine shop true the arbor? Or get one of those oversized bench-top drill presses from harbor freight for $179 (with 20% coupon). I love my drill press although i find it to have a bit to much vibration and a non tilting table. One more factor: My craftsman has a 4” quill stroke and the HF only has 3 1/8” Ideas? thanks! |
#1 posted 221 days ago |
You might want to go for a new drill press. Those huge benchtop ones these days have plenty of power and lots of capability—mine has a laser, LED, and a variable speed lever (no changing belts) and it only set me back $200. I think you’ll find it just as capable as your craftsman, especially if you build a separate stand for it. And you’ll still have the big one to do specific tasks. If you have a Menard’s in your area, check this one out: http://www.menards.com/main/tools-hardware/power-tools/drill-presses/12-drill-press/p-1498047.htm I’ve seen it on sale for $180 at times. Good luck. -- Tristin King -- When in doubt, sand it. |
#2 posted 221 days ago |
Was the DP ever taken apart and restored? Hard to image the quill shaft itself being bent, maybe the chuck was driven on out of alignment. Even if it’s never been apart I’d at least remove the quill and chuck at take a look before you spend money. |
#3 posted 221 days ago |
Cole, there is an exceptionally fine pic story about a C’man DP rebuild on Garagejournal.com. -- bill@magraphics.us |
#4 posted 221 days ago |
Thanks everyone! Bill, unfortunately that not the same one. Thanks though! I think im leaning toward replacing it. What do you think about only a 3 1/8” quill stroke? Also, what goes into truing the arbor? Il try taking the chuck off this weekend. If its not the chuck, i’ll either be looking on craigslist of get this one from harbor freight: http://www.harborfreight.com/heavy-duty-16-speed-bench-drill-press-38142.html or this one: http://www.harborfreight.com/16-speed-floor-drill-press-43378.html Thanks! |
#5 posted 221 days ago |
The basic issue with using a drill press as a router is the chuck versus a collet. The chuck cannot support the entire circumference of the bit while a collet can. If your chuck has too much play it can be replaced. To see how much run out your drill press has, remove the chuck and manually run the taper against a dial indicator follow that with lateral pressure on the taper to check the bearings. The first measurement checks the out of round of the taper. The second checks the bearings. If any of the readings are greater than 0.005” then the taper is out of round and/or the bearings are worn. If the readings are OK then the chuck may be worn. I found this out with my drill press which is not as good as the one you have and all I had to was replace the chuck. -- "I never met a board I didn't like!" |
#6 posted 220 days ago |
I love vintage but I won’t lie – a crank up table would be nice. |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1525 |
3543 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6151 |
