Sheet Optimizer
Forum topic by TPE posted 117 days ago 239 views 1 time favorited 8 replies Add to Favorites
View TPE's profile
TPE
5 posts in 139 days
117 days ago
Topic tags/keywords: optimize sheet good
Hello everyone,
I was wondering if anyone knew of a good program for optimizing sheet material. I have downloaded one or two, but have not found them to be very intuitive.
Any suggestions?
Thank you.
View Mike Lingenfelter's profile
Mike Lingenfelter
403 posts in 651 days
117 days ago
I use CutList. I think I bought the LT version, because most of my projects are smaller. I haven’t used it in a long time, because I have moved away from using sheet goods. When I was using it, it worked great.
-- http://theinquisitivewoodworker.com/
View kewald's profile
kewald
61 posts in 118 days
117 days ago
I use Cutlist Plus and have the Gold version. I find it very intuitive, accurate and helpful. I maintain my inventory in it and can do project estimates using it. Great tool and several versions at good price points.
-- Always do the Right Thing the Right Way the First Time - if you can figure out what that is! Ken, Spring Branch, TX
View RedShirt013's profile
RedShirt013
7 posts in 198 days
117 days ago
I like Cutlist Plus the most also. It requires very little setup for your sheetgood material and the interface is very straightforward, behaves like a spreadsheet with just enough graphics for clarity. Quick switch between different optimization/cut patterns. And it’s quite cheap, with enough function to do most things save large batch panel saw/CNC optimization. COuld even do project costing if you put in a little more time.
-- Ed
View BeechPilotBarry's profile
BeechPilotBarry
410 posts in 239 days
114 days ago
I’ve been using Cutlist Plus for several years and love it. CLP also works great for optimizing trim and molding. You can do “what if’s”, say with 8,10,12, or 16’ stock by changing your in-stock inventory and “can buy more” setting. I also like the printout formats and label printing option.
CLP is less friendly with solid stock for furniture. A good woodworker chooses each part based on figure, defects, and color This is not a knock on the program at all, as I can’t imagine how you’d make a software figure, color, and defect aware of every board! ;^)
-- - Real men read directions
View depictureboy's profile
depictureboy
77 posts in 179 days
114 days ago
I use ecabinets…but lately I have been using sketchup with a plugin.
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
View Yettiman's profile
Yettiman
126 posts in 274 days
114 days ago
Hi,
Is there a lite version for us non professionals. I would only use it a few times a year so could not really justify a lot of expense but it sure would be easier than graph paper.
Thanks
-- Keep your tools sharp, your mind sharper and the coffee hot
View Woodn88s's profile
Woodn88s
44 posts in 78 days
50 days ago
I also use cutlist and like it a lot
-- I want to know Gods thoughts....rest are details "A. Einstein"
BeechPilotBarry
50 days ago
Add me to the choir of Cutlist users.
A nice feature is the ability to start with the basic version and pay only for the feature sets you need. I like Silver…
Bookmark And Share This Page
