Why cant i cut 45 degree cuts for a box?
Forum topic by Cole Tallerman posted 224 days ago 1702 views 0 times favorited 51 replies Add to Favorites Watch
View Cole Tallerman's profile
Cole Tallerman
361 posts in 354 days
224 days ago
So I just got a new sawstop contractor saw, and i cant seem to get perfect 45 degree cuts. I made a jig for picture frames that cuts at perfect 45 degree cuts but when i tilt the blade as if to cut the angles for a box, the joints don’t line up. I made a cross cut sled just for this but the blade angle needs to be at 45. All i do is i turn the hand-wheel untill it stops turning because sawstop claims that everything is aligned and so far, everything is. Do I need one of those digital blade angle readers? Also, when i feel like ive hit the 45 degree stop, With a little more effort the hand wheel will turn another half turn. Is there something wrong with the angle stop?
Thanks in advance!
51 replies so far
View DS's profile
DS
1820 posts in 590 days
#1 posted 224 days ago
Um yah, you’ll probably want to check all your new saw’s setup, especially the 45 degree hardstop adjustment.
It will be worth it, regardless of the company statements.
FWIW, my new saw took almost a week to settle into the new environs, so I repeated the initial setup at that point too.
View paratrooper34's profile
paratrooper34
699 posts in 1121 days
#2 posted 224 days ago
My experience with table saw blades have taught me to use a square or something like that when setting the blade angle. Whether it is 45 or 90, whatever. The scales on the saws are just not accurate enough to guarantee setting the blade by them. For rough measurements, they are good. For stuff that matters, use external reference.
-- Mike
Cole Tallerman
#3 posted 224 days ago
I checked everything except the blade stop and it was dead on. I will try this weekend. What would you suggest i use as a true 45 degree angle? ive used the head of a combination square before.
View Don W's profile
Don W
9952 posts in 737 days
#4 posted 224 days ago
I don’t own a saw stop, but I’ve yet to see a table saw (or any piece of machinery) with that kind of precision built in. You’ll need something to set the blade exactly. one of those digital blade angle readers would be one option. A good 45 degree scquare would work as well.
14858 posts in 2388 days
#5 posted 224 days ago
Yep, you definitely cannot bank on just turning the crank until it stops.
I don’t know about the Sawstop, but with my saw, even when properly adjusted, I can throw the angle out of a perfect 45 just by turning the handle too hard or not hard enough. I always use my digital angle gauge to be sure.
Cole Tallerman
#6 posted 224 days ago
What digital angle gauge should i use? I just spent $2,000 on a table saw so im not looking to break the bank
12060 posts in 1510 days
#7 posted 224 days ago
if you have a good square
cut a board at the 45 angle
and taking the other piece
mate it to the first angle
if it is square
you got 45
if not tweak till they do 90*
(i’m sure there is an adjustable stop bolt
for the stop)
Don W
#8 posted 224 days ago
then a plane and shooting board wouldn’t be a bad idea either.
View shampeon's profile
shampeon
517 posts in 353 days
#9 posted 224 days ago
One of those $20-30 digital angle gauges are pretty much perfect for this. Like a Wixley:
http://www.amazon.com/Wixey-WR300-Digital-Angle-Gauge/dp/B001PTGBRQ
I got mine for like $19 on sale.
87182 posts in 1746 days
#10 posted 224 days ago
When cutting on a miter gauge your material will tend to crawl (move) this can change the angle and the length, it’s very critical for parallel sides to be exactly the same length.
View lab7654's profile
lab7654
184 posts in 416 days
#11 posted 224 days ago
I use a speed square, those are long enough to give a good idea of where you are at. They are usually pretty dead on when it comes to accuracy, even the cheap plastic ones.
-- Tristin King -- When in doubt, sand it.
View 47phord's profile
47phord
136 posts in 406 days
#12 posted 224 days ago
I always set my saw with a metal framing square I bought years ago. It’s dead-on, and I know that my saw is set right the first time.
View knockknock's profile
knockknock
47 posts in 342 days
#13 posted 224 days ago
Tallerman said: “ive used the head of a combination square before.”
As long as you combination square is not poorly made, remove the ruler and the head should have a good 45.
View crashn's profile
crashn
508 posts in 635 days
#14 posted 224 days ago
what you did not mention is that are your cuts short (less than 45) or long (more than 45). Even when set with a guage, square or digital tool, make test cuts in scrap and sneak up on the perfect angle.
-- Crashn - the only thing I make more of than sawdust is mistakes
View GarageWoodworks's profile
GarageWoodworks
312 posts in 326 days
#15 posted 224 days ago
I NEVER trust my positive stops for blade bevel angles. It wouldn’t take much sawdust to throw off your positive stop in your table saw.
The fastest and most accurate method for checking 45 is to use a dial indicator and an accurate 45 degree reference.
-- Subscribe on YouTube: http://www.youtube.com/user/GarageWoodworks?feature=guide
showing 1 through 15 of 51 replies
