installing a stretcher on a nightstand
Forum topic by CharlesI posted 10-09-2012 09:52 PM 664 views 0 times favorited 1 reply Add to Favorites Watch
View CharlesI's profile
CharlesI
2 posts in 2018 days
10-09-2012 09:52 PM
Topic tags/keywords: through mortise and tenon joinery stretcher
I’m working on a nightstand and installing a stretcher at the bottom just below the bottom shelf connecting the two panels. I’m using through mortise and tenon joinery. I’m taking a class and the explanation I’m getting from the teacher is a bit complicated and seems like too many steps. Does someone have a technique that is simple and quick without using any test pieces. I am being required to use a dado set up in the shop tablesaw. Thanks for your suggestions.
1 reply so far
View oldnovice's profile
oldnovice
6755 posts in 3330 days
#1 posted 10-12-2012 05:30 PM
I assume the dado set up is for the tenons! If not I don’t know what else you would use the dado set for in this case. I have seen stretchers between legs but not between panels?
Can you show a drawing/photo for more detail?
