Hinges for Blanket Chest
Forum topic by Marshall posted 10-09-2012 08:10 PM 8682 views 0 times favorited 8 replies Add to Favorites Watch
View Marshall's profile
Marshall
151 posts in 1931 days
10-09-2012 08:10 PM
Topic tags/keywords: chest hinge hinges
Hello,
I’m building a blanket chest out of black walnut. The lid will be 50.25×25.25×1 which I calculated will weigh approx 29 lbs (3.25 lbs/ft2). I really like Lid Stay Torsion Hinges from Rockler: http://www.rockler.com/product.cfm?page=30958&site=ROCKLER, but I’ve only found ones that go up to a 60 in-lb rating..
My hinges will need to support 366 in-lbs (29 lbs x 25.25 in / 2). Does anyone know of similar hinges that are rated for more torque? Or does someone have a better suggestion? I dont like the idea of using six of these hinges, nor do i want to spend that kind of money.
Thanks!
-- Marshall - http://mcomisar.tumblr.com
8 replies so far
13594 posts in 3217 days
#1 posted 10-09-2012 08:28 PM
looks like you will need these to soft close
http://www.rockler.com/product.cfm?page=410&rrt=1
125lb’s each
View MJCD's profile
MJCD
515 posts in 2247 days
#2 posted 10-09-2012 09:40 PM
The Rockler calculator is very conservative; in that, it will over-recommend the number of hinges. I recently completed a Cherry Blanket Chest – the lid had an ‘effective’ weight of 180 lbs – Rockler recommended 3×60; they had two in-stock, which I used – the lid works perfectly with 2×60.
Appreciate that the 60 in-lb rating will tax the holding strength of the hinge screws – the wood and the screws can handle only so much, regardless of the hinges’ mechanical capabilities. If higher-capacity hinges are available, I’m not sure the wood could handle the torque.
On mine, see pictures below, I placed a spacer between the hinge and top – the spacer is glued to the top – spreading the load, with the hinge connected to the spacer: if the spacer is stripped, it can be replace.
My recommendation is to use something less than the 6 (probably 4 or 5, which should look fine); if you need more; we’ll you’ll need more, and can put them on later – I appreciate the layout issues with this, as you would want to equally space 6 or 4, and do not want to make it look like an add-on, or after-thought
MJCD
-- Lead By Example; Make a Difference
View MJCD's profile
MJCD
#3 posted 10-09-2012 09:46 PM
Follow-up:
On the Rockler site, please read all of the user comments – several noted that the screws supplied with the hinges were, in their view, undersized for the task; also, that some of the screws snapped during installation because of the twisting force during installation. I pre-drilled the holes and used slightly larger stainless steel screws – my choice, for your consideration.
I hope this helps.
View MJCD's profile
MJCD
#4 posted 10-09-2012 11:05 PM
Patron’s solution looks like the better choice – I think it will be a) less demanding on the wood contacts; 2) handle your requirements in a less obtrusive and expensive manner.
I would check the user comments, though; these are usually very knowledgeable craftsman.
MJCD
View MT_Stringer's profile
MT_Stringer
3136 posts in 3107 days
#5 posted 10-09-2012 11:55 PM
The lid on the toy box I just finished was made out of white pine so it wasn’t very heavy. I used a piano hinge and two of the lightweight lid protectors sold by Rockler. It won’t close on it’s own, thus protecting little fingers. You have to shut it.
http://lumberjocks.com/projects/72425
View MonteCristo's profile
MonteCristo
2099 posts in 2064 days
#6 posted 10-10-2012 12:41 AM
Brusso makes an awesome hinge for a chest like this. You bury it in the top edge of the side (at the back). Pricey but beautiful solid brass.
View HorizontalMike's profile
HorizontalMike
7736 posts in 2790 days
#7 posted 10-10-2012 12:45 PM
I used the “Lid Supports” that @Stringer mentions, however with my Ash Blanket Chest it took three of them to handle the weight. Maybe a combination of these and the torsion hinges might be an acceptable answer.
Marshall
#8 posted 10-10-2012 12:49 PM
Wow, thanks everyone for all the suggestions. Great feedback!
