Powermatic Lathe 90 or 45?
Forum topic by OnlyJustME posted 10-09-2012 12:14 AM 11559 views 0 times favorited 6 replies Add to Favorites Watch
View OnlyJustME's profile
OnlyJustME
1562 posts in 2370 days
10-09-2012 12:14 AM
Topic tags/keywords: lathe powermatic
Saw a listing for a PM 90 lathe and one for a PM 45 both reasonably priced. I am wondering which of these would be better to get? Any thoughts would be appreciated. Assume both are in similar condition same hp.
-- In the end, when your life flashes before your eyes, will you like what you see?
View liferwood's profile
liferwood
5 posts in 2089 days
#1 posted 10-09-2012 12:42 AM
90 is heavier duty lathe. I’d get it with all things being nearly equal, would probably go a couple hundred more for the 90.
View Wildwood's profile
Wildwood
2305 posts in 2128 days
#2 posted 10-09-2012 01:19 PM
Not sure, anyone can tell you which Powermatic 90 or 45 lathes to get. When got into woodturning could still buy these lathes new from Powermatic. Used ones got top dollar back then. Today prices not as high to buy.
Which one is a complete lathe and operational?
Are you capable of doing any repairs if necessary?
If complete and opeprational either lathe will serve you well.
-- Bill
OnlyJustME
#3 posted 10-09-2012 01:42 PM
supposedly they are both complete. the 90 is somewhat disassembled and the 45 is together. they are both the same hp motor. i just can’t seem to find what the difference in the models is.
i generally have no problem assembling or repairing machines. manuals and some experienced guidance with the tool make it easier and faster of course.
the 45 is actually priced a bit higher than the 90 but i thought the 90 was a bit bigger and more capable than the 45.
Wildwood
#4 posted 10-09-2012 04:56 PM
PM 90 wood lathe” can check vintage machinery for manuals for both lathes.
http://www.toolsandmachinery.com/images/diagrams/Model%2090%20Lathe%20(1971).pdf
Model 45
http://vintagemachinery.org/pubs/655/1276.pdf
I would opt for model 45 because 1” x 8 TPI headstock spindle and less weight. Model 90 has 1 ½” x 8 TPI headstock spindle and weighs in at 600 or 700 lbs. You can still buy 1 1/2” threaded chuck adapters for chucks but 1” x 8 TPI accessories more common.
Only problem with these old lathes once restore is price competition from cheap China mini lathes. Have seen restored PM 90 lathes selling for between $400 to $1,000. Either model in working order un-restored sell for less than $500. If want quality go for the old iron!
-- Bill
View RJ2's profile
RJ2
151 posts in 3779 days
#5 posted 07-16-2014 03:11 PM
i’ll second that , The Powermatic 45’s are so solid. the banjos dwarf the Rockwells.
-- RJ, Tampa Fl, RJMETALWOODS.COM
View RJ2's profile
RJ2
#6 posted 07-16-2014 03:15 PM
i’ll second that , The Powermatic 45’s are so solid. and smooth ,the banjos dwarf the Rockwells.
