Best Clamps For face gluing?
Forum topic by ChrisCarr posted 221 days ago 525 views 0 times favorited 6 replies Add to Favorites Watch
View ChrisCarr's profile
ChrisCarr
196 posts in 1064 days
221 days ago
I need to buy some clamps and am wondering what would be the best kind to buy for face gluing boards together?
I need to glue up three 2×4’s to make nice thick workbench legs and stretchers.
I was not sure what to buy.
The cheaper the better since I will need a lot.
View CessnaPilotBarry's profile
CessnaPilotBarry
598 posts in 275 days
#1 posted 221 days ago
I’d go for Bessey 12” “F” style clamps. Not the cheapest, but far more useful than C clamps.
You’ll use them over and over again…
-- It's all good, if it's wood...
View crank49's profile
crank49
2276 posts in 1136 days
#2 posted 221 days ago
Besseys are good but I prefer Jorgensen because they are made in the USA and actually cost a little less.
It never hurts to have come “C” clamps around the shop as well. I have 4 each of 4” and 6”. For the money, it’s hard to fault Harbor Freight “C” clamps. Their 6” is usually on sale for around $4 or $5 each.
I would recommend at least 4 clamps on something the length of a bench leg.
There is one Bessey clamp I strongly recommend and that is the “C” clamp with a forked end. It gives you three pads , 2 on the forked end and one on the screw. That is really helpful to put in the middle of a glue-up to keep the parts from sliding around. Or you could shoot a brad or two through the boards to keep them aligned.
What ever you do for clamps, you can’t go wrong because you never have too many.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View Bogeyguy's profile
Bogeyguy
127 posts in 233 days
#3 posted 221 days ago
I agree with crank, Jorgensons. Been using them for 40 years and they are the best for face glueing.
View Kreegan's profile
Kreegan
1294 posts in 312 days
#4 posted 220 days ago
Not all Jorgensen’s are made in the USA. Make sure to check for the stamp first if that’s important to you. Adjustable Clamp Co, Jorgensen’s parent company, started offshoring some of their clamps earlier this year.
Rich;)
-- Rich;) -"Dada make a big mess?" "Yes Dada made a big mess."
View teejk's profile
teejk
970 posts in 850 days
#5 posted 220 days ago
tried them all…I keep going back to the 3/4” pony clamps. cheap and adaptable to whatever length you need as long as you have a thread on a piece of cheap black pipe (better yet if you know a plumber with a thread cutter). and I find that little crank handle is much easier to use than the alternatives.
86920 posts in 1742 days
#6 posted 220 days ago
I agree that “F” style clamps work well for face clamping but others will do the job also like pipe clamps,wood screw clamps and even bar clamps with calls if you have enough.
