Making a Dado on a miter saw??
Forum topic by BenI posted 10-08-2012 11:08 PM 6293 views 0 times favorited 4 replies Add to Favorites Watch
View BenI's profile
BenI
332 posts in 2177 days
10-08-2012 11:08 PM
Topic tags/keywords: miter saw lap joint
Sometime soon, I hope to make a coffee table and just working out the details now instead of when a problem arises. I remember a video of someone using a miter saw (with a normal blade) to make dados for half lap joints. I’d like to do this for the corners of the top of it but unsure if this would 1) be a strong enough joint and 2) can a miter saw make a smooth enough dado, if at all?
I know that the blade on mine now is ATB so obviously have to switch it out with a rip blade for a flat bottom but if I did that, would it be accurate for a joint?
Otherwise I’ll just use my router and a fence to make the cut but I thought using a miter saw might be easier.
Thanks in advance for the advice LJ’s!
-- Ben from IL
View JesseTutt's profile
JesseTutt
854 posts in 2109 days
#1 posted 10-08-2012 11:22 PM
You might have to run a plane over the surface. I know that my DeWalt has a depth stop that I can engage, so I have always wondered if I could not do dados.
View BenI's profile
BenI
#2 posted 10-09-2012 04:44 AM
My Dewalt also has a depth stop but I’m not sure how accurate it will be but I think I’ll try on some scrap. Unfortunately I don’t have any planes but just picked up some scrapers which I’d think would work fine.
-- Ben from IL
View Loren's profile
10396 posts in 3647 days
#3 posted 10-09-2012 04:52 AM
You can do it on a sliding miter saw… most of them I expect anyway.
Just rough it out and chisel the bottom.
If you don’t have a slider, forget it.
View BenI's profile
BenI
#4 posted 10-09-2012 05:53 PM
I do have a slider thankfully. I’ll test out on some scrap and see which is easier and makes the best surface.
Thanks for the advice.
-- Ben from IL
