Help with found plane?
« back to Hand Tools forum
Forum topic by MarkwithaK posted 10-08-2012 08:25 PM 1083 views 0 times favorited 11 replies Add to Favorites Watch
View MarkwithaK's profile
MarkwithaK
370 posts in 3050 days
10-08-2012 08:25 PM
I found this old Stanley #4 stashed in my garage. It was stashed away in a tool chest that was left behind when I bought the house. I tried searching on-line to figure out the approximate date but I keep getting stuck in a loop and get frustrated. It was in the original box along with it’s manual. I looked for a copy write date on the paperwork to get a rough idea of it’s age but couldn’t locate such a date….it does however list the prices for replacement parts. There was also a Stanley “Handy Man” plane but from the info I managed to gather from the interweb it’s not considered to be very good. This is the first hand plane I have ever owned and despite not knowing much about proper set-up i did run the iron on my Worksharp and the thing seemed to cut fairly well.
-- If at first you don't succeed then maybe skydiving isn't for you.
11 replies so far
View pwgphoto's profile
pwgphoto
70 posts in 2088 days
#1 posted 10-08-2012 08:32 PM
I would need to see more images to date it. A good site I use for dating them is the Rexmill site. go there and hit the type study link.
-- Paul, Brooklyn Park, MD.
9765 posts in 3520 days
#2 posted 10-08-2012 08:51 PM
Yellow paint on the cap iron, high front knob, Rounded
iron corners.
Look for a heart on the iron.
Maybe a type 13 or 14.
http://home.comcast.net/~rexmill/planes101/typing/typing.htm
View Handtooler's profile
Handtooler
1493 posts in 2004 days
#3 posted 10-08-2012 08:51 PM
Look for an alphabet letter and a number on the frog, the letters and/or numbers are the codes to finding the date range; but I haven’t found the information sheet that answers the same question for me. Mine has U and 6 on the frog as weell as the red orange background on the cap iron that reads Stanley, this color has some significance I’m told; the sole has Bailey No. 4, Made in the USA. Also the shape of the cap iron’s opening straight v.s. kidney shape makes a difference. Am I on target LJers? Good luck.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
16272 posts in 4090 days
#4 posted 10-08-2012 08:53 PM
It’s not real old. Mid 20th-century. Still should make a perfectly good user.
View Mosquito's profile
Mosquito
9187 posts in 2164 days
#5 posted 10-08-2012 09:04 PM
Given what looks like a steel adjustment knob, and the yellow kidney shape, probably 70’s is my guess… Not a type 13-14, those had keyhole lever caps. Kidney’s didn’t show up until later.
Charlie’s right, not real old, but should make a perfectly good user. Just have to tune it up a bit. Still a great find
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View BTimmons's profile
BTimmons
2303 posts in 2357 days
#6 posted 10-08-2012 09:18 PM
Not too bad. You may need to move the frog forward a little bit. The throat looks kinda wide open, which may make it harder to get the ultra thin shavings that a #4 can produce. That’s if you plan to use it for that type of planing, anyway.
-- Brian Timmons - http://www.BigTWoodworks.com
MarkwithaK
#7 posted 10-08-2012 09:43 PM
Thanks for all of your help. After reading through the web site given I was fairly certain it was newer than the any of the ones listed. No patent date, the plane body is maroon and there isn’t a bit of brass anywhere on it. Ultimately all I care about is that it is a quality tool and that I won’t be wasting my time on tuning it up. Thanks again guys.
View Richard's profile
Richard
400 posts in 2564 days
#8 posted 10-08-2012 10:37 PM
I agree with Charlie, it can probably be made to work well enough, but could take some work to get it there.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
Handtooler
#9 posted 10-08-2012 10:44 PM
Mark, Incidently, with regard to the HANDYMAN, I own a what I’ll call a No. 3, but the original box simply says Stanley Smoother, $6.27. My father bought it new at a local hardware store used it a few times out of the box. It was fair, but when I began to learn about tuning and flatening the frog, sharpening the blad and setting the cap iron forward, golly that baby will turn out gossmer strips also. It takes some attention.
View Don W's profile
Don W
18561 posts in 2440 days
#10 posted 10-09-2012 12:04 AM
This is the best place to type it. http://primeshop.com/access/woodwork/stanleyplane/pftsynch.htm
It will be a good user and it shouldn’t take a lot to get it there.
Handyman planes take some work. Its not the place to start.
View hhhopks's profile
hhhopks
650 posts in 2249 days
#11 posted 10-09-2012 01:05 AM
Gents,
I am impressed with the quality of the detective work given with the amount of information given.
-- I'll be a woodworker when I grow up. HHHOPKS
