Metal Finder Recommendation
Forum topic by moke posted 10-08-2012 06:04 PM 1821 views 0 times favorited 18 replies Add to Favorites Watch
View moke's profile
moke
1259 posts in 2953 days
10-08-2012 06:04 PM
A few weeks ago I planed some boards for a friend, and they must have had a nail or something in the original tree. I always carefully look over the boards, but now after paying 150.00 for new blades, I have decided to never plane anything for anyone else and get a “metal finder”. I have found a huge variation in prices…20.00 to 200.00. I could really use some advice from someone who uses one.
I realize I can have the old blades sharpened, which I intend to do, but it is still 50.00 for that. I just want to find a reasonable priced locater that works well.
Thanks,
Mike aka Moke
-- Mike
18 replies so far
MrUnix
7008 posts in 2376 days
#1 posted 10-08-2012 06:19 PM
I’ve used this harbor freight one for a couple of years now. I not only use it to find nails and other stuff in wood, but also as a pin-pointer in conjunction with my metal detector when I’m out digging up coins and jewelry. If you wait for it to go on sale and then use a 20% off coupon, you can pick it up for under $10. The thing works great and is very sensitive. The only complaint I’ve heard from other owners is regarding the switch which is fairly cheap and prone to failure.. however it’s an easy and cheap fix if ever needed (never had a problem with it myself, and I really abuse it). I’ve tried several other more expensive brands and they all seem to do about the same regardless of price. HF also makes a wand type that I’ve heard works pretty well, but I’ve never tried one of those.
View Jacob's profile
Jacob
85 posts in 2819 days
#2 posted 10-08-2012 06:29 PM
This is a smart idea. I once found a lead slug embedded pretty deep a board of walnut straight from the lumberyard. Must’ve been a stray bullet while the tree was still alive.
-- -Jacob Turetsky, Industrial Designer
View toolie's profile
toolie
2147 posts in 2806 days
#3 posted 10-08-2012 07:38 PM
$20 shipped off ebay:
hasn’t missed any metal yet!
View Surfside's profile
Surfside
3389 posts in 2351 days
#4 posted 10-08-2012 09:13 PM
How about this?
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View Moron's profile
Moron
5032 posts in 4071 days
#5 posted 10-08-2012 10:36 PM
I used/use the same one Toolie suggested. Works great.
View JesseTutt's profile
JesseTutt
854 posts in 2288 days
#6 posted 10-08-2012 11:20 PM
One question to ask with any metal detector is how deep will it scan? Would the metal detector detect something in the middle of an 8/4 board. The one I have has problems with boards over 1” thick. As a test, place a nail under a board and see if the scanner will detect it.
Surfside
#7 posted 10-09-2012 01:51 PM
With that multi zone metal detector I posted above can detect even the tiniest metal inside a big board.
View moke's profile
moke
#8 posted 10-09-2012 04:38 PM
Thanks for the advice guys—-I still haven’t decided. I haven’t found the super scan for less than 60.00 anywhere, it looks like a great unit and maybe that is what I am going to have to pay. Any more advice is appreciated.
-- Mike
View moke's profile
moke
#9 posted 10-11-2012 02:37 PM
Thanks again guys. I bought a Garrett unit that looks similar to the Super Scanner. I tried taping a screw to the bottom of the board and it worked semi well. It alerted on 3/4” but very rarely on 5/4 unplaned. I came up eith the idea I should just scan periodically as I plane. Thanks for the advice….
Mike aka Moke
-- Mike
View redSLED's profile
redSLED
790 posts in 2070 days
#10 posted 05-06-2013 01:53 PM
I use the one below – take a 9V battery. Works great. Excellent for dealing with old house/reclaimed wood. Regarding any deep hidden/broken off nails I just cut around them or cut out the piece. Saved my blades many times.
View chloelly's profile
chloelly
1 post in 1933 days
#11 posted 08-05-2013 08:33 AM
Using a high quality headphone help you better catch the signal. Headphone cannot only better transmit the sounds from metal gold detector, it also keeps out the outside noises such as the sound of wind blow, conversation and so on, which will interfere with hearing and recognizing signals.
Shawn Masterson
1325 posts in 2126 days
#12 posted 08-05-2013 12:54 PM
first of all instead of running out and buying new knives just slide the knives. mine has a 3 cutter head so I slide one left, 2 leave it, and 3 slides right. then keep on going till they get dull. I have done this many times. it only takes a little slide to move the chip.
View firefighterontheside's profile (online now)
19266 posts in 2034 days
#13 posted 08-05-2013 01:46 PM
http://www.amazon.com/gp/aw/d/B000VKJ1MM/ref=ya_aw_oh_pii
Works great for me
View waho6o9's profile (online now)
waho6o9
8489 posts in 2754 days
#14 posted 08-05-2013 01:47 PM
How about a big ol rare earth magnet?
#15 posted 08-05-2013 01:57 PM
The zircon that i have can find metal as much as 6 inches deep. You run it flat for a broad search and then turn it the other way to pinpoint the location. I think it was only about 30 or forty $.
