| Forum topic by rhett | posted 478 days ago | 297 views | 0 times favorited | 10 replies | ![]() |
478 days ago |
I am at the table top portion of a recent dining room set commisssion. My client has given me the cherry for the table top, but it is unruly at best. I would not use it, but it has sentimental value to her, it was her deceased father’s. I have always made my tables with the grain going length wise and breadboard ends. The only way to tame this stack of wood is going to be to cut it down, flatten it and run it with the grain perpendicular to the length. Should I be worried about the 10 1/2” overhang on the ends of the table. It is a modified trestle design so there is no support on the ends. I am afraid it will cup or break off should someone sit on it. Suggestions please. The final dimensions are to be 34×75 with two leaves in the middle that are 45” combined. All boards will be 5” wide and I am hoping to get them flat by 13/16”. -- http://www.efcabineture.com/ You can be tired, or you can be broke, but you should never be tired and broke. |
