4/1000s runout on router?
Forum topic by JesseTutt posted 10-08-2012 03:31 PM 1603 views 0 times favorited 7 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
853 posts in 2018 days
10-08-2012 03:31 PM
Topic tags/keywords: question router runout alignment
I am doing the fall tool alignment. Table saw was perfect, drill press had no runout, jointer was within 1/1000, then I got to the two router tables.
The first router table has runout of about 4/1000s. I used my dial indicator in a miter gauge slot and a 6” stainless steel rod. The rod was advertised as a perfectly straight rod for alignment purposes. As I turn the router collet manually I notice the indicator fluctuate with a change of about 4/1000s. Is this acceptable?
The second router table has runout of around 12/1000s. This table is different because I have a router bit extentor between the router and the rod. With the router mounted in the original Rout-R-Lift the collet can’t get close enough to the top of the table to allow most bits to work. I think I got the extendor from CMT or maybe MLCS. Using the same procedure as the previous router I get 12/1000 runout. Is this acceptable?
Here is a couple of pictures from table #1:
Both routers are Triton 3 1/4 HP. The one in table 1 is newer and has the above the table adjustment built in. Router 2 is older and does not have the adjustment, hence the need for the router lift.
7 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2484 days
#1 posted 10-08-2012 04:23 PM
The spec might seem high since you’re measuring pretty far from the collet.
The other one is most certainly caused by the extender.
View HorizontalMike's profile
HorizontalMike
7747 posts in 2821 days
#2 posted 10-08-2012 04:46 PM
All I can say is when my Harley crankshaft was 0.006” out, I had to rebuild the motor. That said, have you checked the collets as the possible culprit? The router with 0.012” runout may be a combination of issues to get THAT much runout.
JesseTutt
#3 posted 10-08-2012 11:26 PM
Today I tried measuring the runout close to the table top and got the same amount of runout. I know that it is not the alignment pin because in the drill press it showed no runout.
View Alexandre's profile
Alexandre
1417 posts in 2098 days
#4 posted 10-08-2012 11:30 PM
I think it is accurate enough for me :P
-- My terrible signature...
View GarageWoodworks's profile
GarageWoodworks
530 posts in 2064 days
#5 posted 10-08-2012 11:37 PM
When you start using router bits that are as long as the distance at which you took your measurements, then maybe.
-- Subscribe on YouTube: http://www.youtube.com/user/GarageWoodworks?feature=guide
View MonteCristo's profile
MonteCristo
2099 posts in 2096 days
#6 posted 10-09-2012 02:52 AM
4 thou seems a bit high but probably not that unusual. 12 thou definitely seems high.
View MNgary's profile
MNgary
296 posts in 2324 days
#7 posted 10-09-2012 03:25 AM
Put a straight-edged bit in the router and edge a 3’ board. Can you feel ripples when you run your finger along the edge?
Hand rub a shellac finish on the edged board (sanding between costs) and use a bright light to inspect it. Does it look acceptable?
-- I dream of the world where a duck can cross the road and no one asks why.
