shouldn't be, but there is a difference.
Forum topic by RussellAP posted 222 days ago 446 views 0 times favorited 6 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 451 days
222 days ago
Have you ever noticed that when you work with 2×2 stock in pine and or cedar, you get dried out fiber that simply won’t become smooth no matter how much you sand on it?
Next time you need some 2×2 stock, rip a 2×4 in half. I don’t know why, but the wood is always denser and easier to work.
Thoughts?
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
View Monte Pittman's profile
Monte Pittman
7029 posts in 503 days
#1 posted 222 days ago
Lumber yards screw you every chance they get. Long road of disgust for me.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
View Gene Howe's profile
Gene Howe
3176 posts in 1593 days
#2 posted 222 days ago
Most 2X is because of thestock in this area isn’t pine. Could it be that the difference in density and workablity is due to the difference in species?
As to cedar, I haven’t a clue. My experience with cedar has been limited to scraps of fencing and used in intarsia.
Maybe Monte’s right. Crappy lumber to begin with.
View teejk's profile
teejk
970 posts in 849 days
#3 posted 222 days ago
I think 2×2 is only a result of “culls” that couldn’t make it as something bigger (meaning it had some inherent flaws and should have been firewood).
View MrRon's profile
MrRon
1571 posts in 1408 days
#4 posted 222 days ago
I have never seen 2×2s that were straight enough to be usefull. I think 2×2s are the last cut from a board that won’t yield a 2×4. That last piece will be from the outer rings of the log it was cut from and have all kinds of stresses built up. The moisture content will probably be different going toward the outer rings. For that reason, if you start with a 2×12, you will find the wood is flatter and you can rip better pieces from it.
View hhhopks's profile
hhhopks
546 posts in 542 days
#5 posted 222 days ago
Yeah, HW stores sells great lumber ;-)
How well seasoned are these lumber?
Will wet wood sand well?
-- I'll be a woodworker when I grow up. HHHOPKS
View Bluepine38's profile
Bluepine38
2082 posts in 1250 days
#6 posted 221 days ago
I just finished most of my new deck, and nearly all the balusters were cut from cants made from pine beetle
killed trees. Even the select wood you buy, if you can even find select, has to be picked through to get good
boards. Most of the big old trees are gone, and it is going to be a while before any more are planted and get
to grow that big. One more thing we have to live with.
-- As ever, Gus-the 74 yr young apprentice carpenter
