| Forum topic by Alexandre | posted 228 days ago | 425 views | 0 times favorited | 6 replies | ![]() |
228 days ago |
Since there are so many handsaw and hand tool fanatics, I am wondering how to remove some of the set in the teeth of a handsaw. -- My terrible signature... |
#1 posted 228 days ago |
As I understand it, the usual method is to stone the sides evenly using a fine grit. I’ve only tried it once on an inexpensive saw, and it seemed to do the trick. I’m no expert on the subject, though. Maybe more experienced LJs can offer better advice. -- John, BC, Canada |
#2 posted 228 days ago |
Hi Alexandre. ...............Jim -- Jim Jakosh.....Practical Wood Products...........Learn something new every day!! |
#3 posted 227 days ago |
Put the teeth of the saw inside a piece of paper (check the thickness of the paper so you know how thick it is.) Place the saw teeth with paper on both sides inside a preferably metal vise with two flat pieces of steel on either side of the saw plate/teeth and paper. Tighten the vise as much as possible. Repeat, as necessary, until the entire toothline of the saw has been squeezed. Your saw will have approximately the same amount of set to each side as the thickness of the paper. This is a method ascribed to Mike Wenzloff currently but one I understand that he picked up from past practice. It works. I’ve done it. |
#4 posted 226 days ago |
Okay, Thanks! -- My terrible signature... |
#5 posted 226 days ago |
I usually run the saw over an abrasive surface, either some 320 grit sandpaper on a granite block, or a coarse diamond stone. Do both sides evenly and take a small test cut after each pass to see if you’re getting the kerf you want. It helps to use a block of wood to ensure solid contact with the abrasive. Rich;) -- Rich;) -"Dada make a big mess?" "Yes Dada made a big mess." |
#6 posted 226 days ago |
Two sources I read and follow both addressed removing some of the set from a hand saw and they both said to lightly draw a file down each side once or twice. Lightly is key. Then try cutting to check your progress. You can make another pass if necessary. I would advise against putting it in a vise and crushing the set. The amount to remove to get the set right is very small and crushing in it in a vice can remove it all very quickly and unevenly. I fixed a rip saw that had a massive set on it and just two passes each side with a file got it done. Good Luck. -- Mike |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1531 |
3547 |
15772 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2839 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
