Setting up a jointer question (pics inside)
Forum topic by Cosmo posted 231 days ago 306 views 0 times favorited 1 reply Add to Favorites Watch
View Cosmo's profile
Cosmo
8 posts in 1530 days
231 days ago
Topic tags/keywords: jointer set up blades
So I made one of those magnet jigs to hold the blades while you tighten the screws except, I can not figure out how to loosen the blades. lol.
There were the two obvious onethat I un-tightened, and the one across from those appear to raise and lower the blade height. But the blade is still wedged in very tight. Any ideas.
The second picture shows two screws located in-between two of the blades. Are these keeping everything(all 3 blades) tight?
This appears to be an old craftsman if that is of any help.
Thanks
pic 1
picx 2
-- Who is Joseph Cotton! Giddy-up
1 reply so far
View Handtooler's profile
Handtooler
396 posts in 304 days
#1 posted 231 days ago
On my Craftsman of 1978, the aluminum bar with the two hex head cap screws is loosened. I remove the screws. . The bar needs to drop down to release the tension on the blades. It’s most often jambed in REAL tight and requires a good rap or so with a hardwood block and hammer. Sometime I’ll take a large screwdriver and pry a little from the ends of the bar to get it to loosen. At any rate the screws under the blades only raise and lower the blades to proper height with that bar loose, the bar is wedge shaped and jams the blades tight against the roller when it’s tightened..
-- Russell Pitner Hixson, TN 37343 bassboy40@msn.com
