Easy & quick Edge Jointing with a router
Forum topic by Oldtool posted 225 days ago 713 views 1 time favorited 5 replies Add to Favorites Watch
View Oldtool's profile
Oldtool
938 posts in 357 days
225 days ago
Topic tags/keywords: resource jig tip trick router jointer milling joining
Having a need to edge joint manu boards for my current project, which I always did by hand in the past, I wanted a quick and easy way to keep this project moving. (Actually, it was the wife who this project is for & she said she hasn’t seen much progress lately) So, I decided to try this following method:
Clamp a 4 ft or 6 ft metal straightedge to my bench and use a straight router bit with a bearing typically used for following a pattern. After I stared this process, I noticed that the space between the cutter and the bearing required an additional height adjustment, so I used two wooden yard sticks clamped between the board and the metal straightedge. This worked out quite well, was very quick – to set up and to swap boards, and best of all, was dirt cheep as I had all I needed to do the job. The included photos with this Forum show;
The initial set up, the bearing position on the metal straightedge, and the finished joint.
Thanks for reviewing, I hope it helps some of you out there in woodworking land.
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
5 replies so far
View cutworm's profile
cutworm
684 posts in 959 days
#1 posted 225 days ago
Thanks for the post. Looks good.
-- "Actions speak louder than words but not nearly as often." - Mark Twain
12048 posts in 1507 days
#2 posted 225 days ago
in the boatyards i worked in
i never did see a jointer
we had a straight board
with formica edges
and just clamped it under the wood
to be straightened
with a trim bit
mostly for cabinets
as boats don’t have to many straight and square
pieces in them
good tip
View MonteCristo's profile
MonteCristo
2060 posts in 354 days
#3 posted 225 days ago
Slick trick for anyone without a power jointer !
Oldtool
#4 posted 225 days ago
Monte – no power jointer, that’s me.
Sounds the same as your Formica board procedure patron. I’ve been hand jointing boards for the last 9 years with much frustration trying to keep the Stanley no. 7 square. Wonder why this didn’t occur to me before. So simple and easy.
Hope you guys get some benefit from this post.
Thanks.
View MattHartzell's profile
MattHartzell
12 posts in 228 days
#5 posted 225 days ago
I do essentially the same thing, only I use a top bearing bit and clamp the straight edge to the top. I have also just used the edge and the edge of the router base.
