Working with bent wood.
Forum topic by RussellAP posted 230 days ago 605 views 0 times favorited 8 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 457 days
230 days ago
These are a few pieces I made the last couple of days. It’s red oad and walnut layered and glued in a mold. The mold is simply a piece of old 1×12 with holes cut for stays, (the pieces that keep the wood in shape while drying).
If you know of a good jig I could make to get uniform 1/8 or less strips, please link it.
As you can see, I didn’t have very square pieces to begin with. I’ve since squared my lumber and adjusted my TS fence to cut straight. The next one in the mold is much better, but I expect that it will become perfect as soon as I can figure out how to cut those strips at the same thickness.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
8 replies so far
View Gary's profile
Gary
3550 posts in 1603 days
#1 posted 230 days ago
There are several jigs on LJ’s for cutting thin strips. One was posted just in the past few days. You should have no problem finding it or some of the others. Easy to make and works every time
View tenontim's profile
tenontim
2129 posts in 1914 days
#2 posted 230 days ago
+1 what Gary said, and I usually run the strips, when I laminate, through either the planer of drum sander, to get uniform thicknesses for the glue up.
-- Tim-- http://www.tmuli.com
RussellAP
#3 posted 230 days ago
Tenontim, I have a $600 planer that I never use. I use the jointer to get a straight side after I make sure the board is square. It would be easier to create a jig that would give me uniform cuts.
View Jacob's profile
Jacob
73 posts in 812 days
#4 posted 230 days ago
Russell, why dont you use your planer? The tablesaw will give you uniform cuts but its so much waste!
I would recommend veneers for bent lamination (or bending ply in the middle and veneer on the outside) because the thinner wood moves very little and create a more stable lamination.
however if you are cutting your own strips you really oughta do a bandsaw then thickness planer/sander operation to limit waste. If your cutting strips your losing a 1/8th of material for every strip!
another plus, veneers and bending ply dont require training for the gentle curves your are experimenting with in this post.
-- -Jacob Turetsky, Industrial Designer (student), www.Coroflot.com/Jturetsky
RussellAP
#5 posted 230 days ago
Jacob, I’ve tried the BS but I end up with just as much waste because after each cut the board has to go to the jointer again so the next cut will be straight. I should really have a BS with a fence, but I don’t. I’m going to use some MDF to increase the table size and I could use clamps and a straight board for a fence I guess, but it takes so long and the waste improvement isn’t all that much compared to the TS.
I did buy a Frued thin kerf blade today, so that will help.
View oluf's profile
oluf
252 posts in 1209 days
#6 posted 230 days ago
I just typed in ( thin strip cutting jig ) at the top of this page in the search box and got 10 hits
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
RussellAP
#7 posted 230 days ago
Thanks Oluf. I found one that is very simple.
View Dan Lyke's profile
Dan Lyke
1367 posts in 2295 days
#8 posted 230 days ago
I use a Festool circular saw on a rail with this rip jig to create thin strips like the ones you show. A lot of waste in the saw kerf when cutting strips that thin, though. I’d rather do this on a bandsaw.
