bandsaw blade
Forum topic by knotheadswoodshed posted 10-04-2012 03:07 PM 2275 views 1 time favorited 7 replies Add to Favorites Watch
View knotheadswoodshed's profile
knotheadswoodshed
219 posts in 2169 days
10-04-2012 03:07 PM
I have a new Rikon 10-325 BS. I have decided on the Lenox Kerfmaster, but am looking for blade width advice.
People seem torn between the 1/2” and the 3/4” BS blades (regardless of Brand), citing tensioning issues. My question is, Lenox also makes a 5/8” blade…would that be a happy medium or am I missing something?
I should mention that my main use of this blade is to take 1/8” slices off of large, figured/exotic woods
-- Randy - "I dont make mistakes, I make design change opportunities" www.knotheadswoodshed.com
7 replies so far
View HalDougherty's profile
HalDougherty
1820 posts in 3234 days
#1 posted 10-04-2012 03:18 PM
Timberwolf blades are great on my Rikon 10-325. I’ve used both the 1/2 & 3/4” blades. They both work great for resawing, but most of the time I go with the 1/2”.
-- Hal, Tennessee http://www.first285.com
View HorizontalMike's profile
HorizontalMike
7757 posts in 2911 days
#2 posted 10-04-2012 03:29 PM
I am successfully using a Timberwolf 3/4 3TPI blade on my 14” Rikon 10-325. That said, it is indeed tensioned to the max (literally) in order to pull this off. Your own example of the 10-325 may or may not support the tension required for a 3/4” blade, it is THAT close.
I would wholeheartedly support trying a 5/8” 4TPI blade on this BS. This would be a great compromise IMO, and that should give you flexibility in tensioning the blade.. And ALWAYS use the de-tension lever after each use, to promote greater longevity of the tension spring.
knotheadswoodshed
#3 posted 10-04-2012 03:34 PM
thanks Mike,
your post regarding this subject in another thread is what got me to wondering if the 5/8” would be a viable compromise.
I have used the Woodslicer for a few years on another (smaller) BS and it seems to work well for me, thats why I thought I would go with the Kerfmaster, as it seems to be the exact same blade, but signifigantly cheaper.
View Surfside's profile
Surfside
3389 posts in 2170 days
#4 posted 10-04-2012 04:15 PM
Tensioning different blade widths shouldn’t be an issue because you can adjust the tension required in each blade. Regardless of the brand of blade, the things that you should consider are the TPI of the blade, the type of wood you’re cutting(hardness, abrasiveness), and the size of the wood. Though tpi and the size of the wood should come along because a bigger piece of wood needs to have a coarser tooth pitch to have bigger space on the gullet area allowing the saw dust to move out of the cut. Also, if you need to resaw woods in thinner pieces, you also need to consider the blade’s kerf.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
knotheadswoodshed
#5 posted 10-04-2012 04:36 PM
the Kerfmaster/Woodslicer is a 3/4 TPI blade, regardless of width.
the wood types cover the gammut from spalted maple and maple burls to ironwood, amboyna and afzelia..just to name a few
HorizontalMike
#6 posted 10-04-2012 04:36 PM
Randy,
FWIW, the “stock” blade that came with my Rikon 10-325 (and probably yours as well) is a 5/8” 6TPI which, by and large, is a decent “general purpose” blade. I really had no complaints (regardless of the online rants about ‘stock’ blades) about this blade. I do think a better choice, as I mentioned earlier would be the 4TPI version because it will cut quicker cleaner than the 6TPI. Will that change in TPI help better control blade drift, I do not personally know whether it would help or not.
I do have to say that when I moved to the 3/4 3TPI all drifting of the blade was history for me. Maybe I could have run a bit tighter on the 5/8” for a better cut, I don’t know. I do know though that I had the tension set to the 5/8” mark on the scale. Wider blades do track better, there is no question about that.
knotheadswoodshed
#7 posted 10-04-2012 04:49 PM
Mike,
I havent set up my new BS yet, as I am transitioning to a new shop, so I dont know about the stock blade.
The kerfmaster is a 3/4TPI. the 1/2” Woodslicer (also 3/4tpi) I had used on a 12” Jet worked really well, so I will try the 5/8” Kerfmaster and see how it goes.
For 18 bucks from Spectrum Supply, I dont see any downside to trying it out.
thanks to all for your input
