Delta DJ-20 Leaving Wood Concave
Forum topic by BerBer5985 posted 230 days ago 498 views 2 times favorited 9 replies Add to Favorites Watch
View BerBer5985's profile
BerBer5985
391 posts in 589 days
230 days ago
I’ve been working on tuning up my DJ-20 jointer that I just got a few days and after getting the knives set and going though one round of making the tables co planar and everything, I finally ran my first board through, which was a junk piece of 4×4 about 36” long. After checking it, it’s leaving the board concave in the middle with about an .011” – .012” dip in the middle. I first though the knives were set to high so I did it again, reset all of them, and tried it again. Seemed to get slightly better, but still about the same. I set the tables with the only straight edge I have which is the veritas 36” aluminum straight edge. I checked the tables again and as far out as the straight edge will go, it seems they are co planar, although they might be off slightly on the far ends, but the straight edge won’t reach? Any suggestions? I thought maybe my technique but with it being a 4×4, I doubt there would be much deflection in the middle. Any other thoughts?
-- Greg, Owner, Quality Carpet One, www.qualitycarpetonecrofton.com
9 replies so far
View MedicKen's profile
MedicKen
1560 posts in 1631 days
#1 posted 230 days ago
Sounds like you may be applying too much pressure to the board as it passes over the knives. It should onlu take enough to hold the board down to the table, let the machine do the work, not you.
12059 posts in 1510 days
#2 posted 230 days ago
outfeed table might be a tad to low
i adjust by running two boards together on edge
and mating those two edges
if outfeed to low
the ends will touch
but middle don’t
if out feed to high
the middles touch
but not the ends
i don’t have any gauges or ever used one
just different cab shops i’ve worked in
taught me quick ways to adjust tools
like fence parallel to table saw blade
if the board throws sawdust from the fence side
the back of the fence is to loose
if it throws sawdust from the saw side
the back of the fence is to tight
when it quits throwing sawdust
i just go back to work
View Roger's profile
Roger
9191 posts in 973 days
#3 posted 230 days ago
I agree with MedicKen and Patron. Also, your pressure should be on the outfeed table, past the knives
BerBer5985
#4 posted 230 days ago
I tried a few times changing my technique and was continually getting the exact same results, so then I raised the outgrew table ever so slightly and got to within .004” over 36”. I may play one more time, but if not, I think I can live with the thickness of a sheet of paper over a long span. Plus I have the Byrd on its way, so I doubt it’ll be a problem after that! Thank god!
View gfadvm's profile
gfadvm
6635 posts in 859 days
#5 posted 229 days ago
David- Your tips and tricks are always so practical and common sense. Thanks for your contributions!
View MonteCristo's profile
MonteCristo
2060 posts in 358 days
#6 posted 229 days ago
4 thou is pretty well as good as it gets I would say.
View pintodeluxe's profile
pintodeluxe
1747 posts in 982 days
#7 posted 229 days ago
Try using a feeler gauge and a little longer straightedge. I shoot for within .002” of coplaner.
Then try another board. I have ran into a couple boards that were so uneven or twisted, that no jointer could fix them.
BerBer5985
#8 posted 229 days ago
I ordered a lee valley 50” straight edge even thought I have the 36” already, but I’m going to check the tables one more time. But right now, the wood is coming through slightly concave around .003” over a 36” piece. Which I don’t think is too bad. I’d love it to be closer to less than .001” if I can but I may be searching perfection that I can’t find. I’m sure that that could also be cause by the tables not being 100% flat. There’s a .0025” concave area in the middle of the out feed table that is probably the cause of the imperfection. I think it’s livable.
View Milo's profile
Milo
802 posts in 1488 days
#9 posted 229 days ago
Greg,
I had problems using a jointer forever. One thing that finally helped me out was using two push blocks to move the wood over the blades. For some reason it helped me distribute the pressure properly. You might try that.
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
