Common Size (but evidently custom?) Dust Collection Reducer
Forum topic by Alex1803 posted 233 days ago 756 views 0 times favorited 11 replies Add to Favorites Watch
View Alex1803's profile
Alex1803
7 posts in 935 days
233 days ago
Topic tags/keywords: dust collection fitting reducer vacuum
Does anyone know of a source for a 2-1/4” ID x 1-1/2” ID (OD’s don’t matter) dust collector/shop vacuum reducer/fitting?
This is to allow me to use my Oneida Dust Cobra (or really any vac system with a conventional 2-1/2” hose) with my smaller power tools – Porter Cable ROS, Dewalt router, Dewalt miter saw, Bosch jigsaw – all of which have a 1-1/2” OD dust port.
I suppose I could turn one out of some easily machined plastic or have a sheet metal contractor custom make one if I can’t find a source.
Any help would be great.
Thanks,
Alex
11 replies so far
View cstrang's profile
cstrang
1747 posts in 1340 days
#1 posted 233 days ago
maybe something like this could work for you, just cut off the reducer to the size you need.
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
View toolie's profile
toolie
1117 posts in 800 days
#2 posted 233 days ago
this is one of the best things i’ve gotten for joining disparate size hoses:
http://www.ridgidparts.com/accessories/VT1755.phtml
Alex1803
7 posts in 935 days
#3 posted 233 days ago
cstrang – A universal fitting like this one – only with another reducer on the big end, unfortunately – would work. It becomes very bulky and cumbersome, though, and for some tools (e.g., the router and jigsaw) it also becomes dangerous.
toolie – Unfortunately, your kit will not work either. This is also a prime example of manufacturers not listing what the dimensions refer to – ID? OD? Both?
View Lynden's profile
Lynden
28 posts in 1318 days
#4 posted 232 days ago
Check with Amflex to see if they have the adaptor you’re looking for. I see they also make custom parts. Maybe they could make an adaptor for you.
http://catalog.amflex.com/category/hose-accessories
Alex1803
7 posts in 935 days
#5 posted 232 days ago
Thanks, Lynden. I’ll give them a try.
Lynden
#6 posted 232 days ago
Also, I’ve had good luck with Bosch adapters. Call Bosch CS and ask them for the I.D.s and O.D.s of their different adapters. There is also information about size and/or tool compatability in the Amazon customer reviews of each Bosch adapter.
http://www.boschtools.com/Products/Tools/Pages/ItemResults.aspx?catid=1039
Lynden
#7 posted 221 days ago
Alex—Did you find the adapter you were looking for? I was home last week and I measured my various adapters. As close as I can measure it, the Bosch 2605702022 adapter has a 2-5/16” I.D. on the large end and a 1-9/16” I.D. on the small end. These dimensions may taper to a slightly smaller dimension on the inside. Also, the large end has a second ring on the inside which may or may not have to be removed for your application. Amazon sells it.
http://www.boschtools.com/products/tools/Pages/BoschProductDetail.aspx?pid=2605702022
View Elizabeth's profile
Elizabeth
639 posts in 1315 days
#8 posted 221 days ago
I’m in a similar boat in that I’m trying to hook up my DeWalt miter saw to a standard 2 1/2” dust hose. I’m going to try either this or this and I will let you know if either works!
View gfadvm's profile
gfadvm
6654 posts in 862 days
#9 posted 221 days ago
That foam pipe insulation works well to ‘shim up’ a too small hose fitting.
View ihmserv's profile
ihmserv
30 posts in 1941 days
#10 posted 221 days ago
this is what i use and most box stores or plumbing suppliers carry them.
http://www.fernco.com/plumbing/flexible-couplings/stock-couplings
IAN
-- woodturners keep things spinning.
Elizabeth
#11 posted 219 days ago
Update – neither of those products I linked worked for my Dewalt, even though the set of three adapters worked on a Dewalt display model in Home Depot. It must not have been the exact same model.
