White Paint Recomendations for Gravity Fed Gun
Forum topic by JSB posted 10-03-2012 10:14 PM 1246 views 1 time favorited 7 replies Add to Favorites Watch
View JSB's profile
JSB
737 posts in 1954 days
10-03-2012 10:14 PM
I have a need to spray paint on a coming project. I’m looking for good paint recomendations for a gravity fed spray gun. I happened to have some white MasterHide latex paint that I tried. Too thick from the can, wouldn’t even spray. Thinned it 50/50 with water and it still seemed too thick. The largest gun needle I have is a 1.4mm. Can anyone who is using a gravity fed gun with success spraying paint give their setup? I have searched and searched but cant seem to find good info. Should I avoid latex all together and use an automotive type paint? I see a lot of spray painted cabinets that look great on here!
-- Jay - http://www.jayscustomcreations.com
7 replies so far
View Monte Pittman's profile
Monte Pittman
27763 posts in 2214 days
#1 posted 10-03-2012 10:16 PM
Painting is absolutely my worst area. Good luck.
-- Mother Nature created it, I just assemble it.
View TheOldTimer's profile
TheOldTimer
226 posts in 2962 days
#2 posted 10-03-2012 10:31 PM
I would not use latex paint as you will have to thin it to the point that several and I mean several coats will be needed. In addition, gloss latex if thinned too much will not get a schene. My recommendation would be to use pigmented lacquor (water base) from one of the suppliers such as Target coatings or Hood finishing supplies. Target will mix custom collors and Hood sells black and white pigmented water base lacquor. You will find both on the internet.
-- TheOldTimer,Chandler Arizona
View AandCstyle's profile
AandCstyle
2951 posts in 2133 days
#3 posted 10-03-2012 10:42 PM
You should check with Jeff Weiss of Target Coatings to see if your needle will work with this product. I think it will, but he knows all.
http://www.targetcoatings.com/shop/catalog/EMTECH_EM6500_Bright_White_Pastel_Base_Coat-35-1.html
-- Art
View Clint Searl's profile
Clint Searl
1533 posts in 2237 days
#4 posted 10-03-2012 11:25 PM
Try Sherwin-Williams white solvent lacquer.
View NiteWalker's profile
NiteWalker
2736 posts in 2453 days
#5 posted 10-04-2012 05:03 AM
Crystalac makes a white top coat in gloss or satin finishes. I’ve used the gloss and it comes out great.
View exelectrician's profile
exelectrician
2327 posts in 2303 days
#6 posted 10-04-2012 05:14 AM
My medicine cabinet project I used 25 – 30% Flotrol. Flotrol is a special thinner for spraying latex through HVLP guns.
This was my first time spraying latex so there was a little bit of trial and error but I quickly found the best settings and the job went really well.
-- Love thy neighbour as thyself
View Earlextech's profile
Earlextech
1160 posts in 2566 days
#7 posted 10-04-2012 06:16 PM
One of the best things you can do for spraying latex of any kind is to stir it using a mixer on a drill. This will shear the molecules of the paint so that they spray better.
Floetrol is not a thinner. Floetrol is a latex additive that breaks the surface tension of the paint and allows it to flow out better. Water is the proper thinner for latex.
With HVLP systems that needle is fine. Thin your paint with 10% water, add 2 ozs of Floetrol, stir with a drill.
On the other hand. Latex is never the proper finish for any furniture or cabinetry. Solid color lacquer, from anyone, is a better finish coat.
