sharpening with a bench grinder(which way should the wheels turn?)
Forum topic by shelly_b posted 10-02-2012 10:42 PM 5504 views 1 time favorited 11 replies Add to Favorites Watch
View shelly_b's profile
shelly_b
850 posts in 2085 days
10-02-2012 10:42 PM
I got a set of razor sharp wheels for my bench grinder and the instructions say the wheels should be turning away from the sharp edge. My bench grinder wheels turn down, which would be the opposite of what they suggest. Should I go to the back of the grinder so the wheels are turning up?
11 replies so far
View teejk's profile
teejk
1215 posts in 2652 days
#1 posted 10-02-2012 10:58 PM
is it as simple as saying holding a chisel pointing up as the wheel rotates down?
View paratrooper34's profile
paratrooper34
915 posts in 2919 days
#2 posted 10-02-2012 11:32 PM
Shelly, the wheel should be turning down, the way you describe it. This directs sparks and debris immediately down instead of sending them airborne. I have never seen a grinder that works differently than that.
Good Luck
-- Mike
View thedude50's profile
thedude50
3603 posts in 2445 days
#3 posted 10-03-2012 12:27 AM
Yes what para Trooper SAID IS CORRECT.
-- Please check out my new stores http://woodratnest.com and http://woodshopstore.com
View shipwright's profile
shipwright
7966 posts in 2765 days
#4 posted 10-03-2012 01:07 AM
Those are great instructions.
Sort of like saying “In case of fire, RUN” but not telling you which way.
HillbillyShooter
5811 posts in 2260 days
#5 posted 10-03-2012 01:45 AM
As I understand the Razor Sharp system, it is a honing system you use similar to the leather honing wheel on the Tormex system. If you check their web site, it shows the wheels being used on a buffer, not a grinder. A grinder cuts into the metal to sharpen as observed above, but a honing wheel works by polishing the edge by spinning away from it—when you hone on a leather surface you pull the sharp edge away from the edge not push the edge into the leather surface. The Razor Sharp wheel needs to be turning away from the edge, not into the edge as the latter will cause the blade to catch/cut into the wheel and be thrown downward. Also, if you’re not clear on how to use the Razor Sharp Wheel, the web site has a telephone number and I strongly recommend you call and make sure you understand how to use the wheel as cutting into the wheel as it rotates towards the edge could result in a nasty accident.
shelly_b
#6 posted 10-03-2012 06:46 PM
thank you, hillbillyshooter- that was what I was worried about since the edges are somewhat soft I didn’t want it to catch the edge. And since they are honing wheels and not grinding wheels, they really don’t throw much debris or sparks. I read the instructions but they were confusing. For knives and scissors it was clear that the wheel should not turn towards the cutting edge, but the instructions for woodworking tools were not very clear…I will see if the video can help clear it up. thanks! if anyone has these wheels
View Bill White's profile
Bill White
4907 posts in 3928 days
#7 posted 10-03-2012 08:03 PM
DO NOT POINT THE CHISEL UP!!!!
Point should be DOWN-handle up.
Look at some vids on the Tube or elsewhere.
I set the points up for sharpening, and down for honing.
If my comments are redundant, so be it.
Listen to ‘Trooper.
Bill
-- bill@magraphics.us
HillbillyShooter
#8 posted 10-03-2012 11:44 PM
See the following link for what I think Bill White is strongly recommending for safety reasons:
http://www.grizzly.com/catalog/2012/Main/220
Note the knife appears to be a lock back, so be careful not to place your fingers where any blade could close and cut—be careful and use common sense to avoid injury.
thedude50
#9 posted 10-04-2012 03:13 AM
if this is going on a grinder to get on the back side of it your going to have to remove the guards and such or so it seems to me
shelly_b
#10 posted 10-04-2012 06:16 PM
It says that you donts need the gaurds so i can remove them so i dont uave to hold my tools upside down to sharpen them. Thanks for everyones help?!
View madcap's profile
madcap
1 post in 1201 days
#11 posted 01-08-2015 11:51 PM
It depends on what you are grinding. Most of the time you will want to have the wheel turning down but if you are sharpening wood chisels you will get better results if the wheel is turning up. With most grinders you don’t have a choice. Many carvers use a belt driven wheel and buffer on a mandrill. Worked for me
