Radial Arm Saw table Adjustments
Forum topic by wood_warrior posted 10-02-2012 10:15 PM 2033 views 0 times favorited 9 replies Add to Favorites Watch
View wood_warrior's profile
wood_warrior
15 posts in 1965 days
10-02-2012 10:15 PM
I have a powr-kraft radial arm saw without a table or rails. It’s just the base. I have a pretty good idea how to build the top according to the Mr. Sawdust plan, but I don’t know what mechanism to use to adjust the height. In other words how to I raise and lower the different corners?
9 replies so far
13594 posts in 3244 days
#1 posted 10-02-2012 10:32 PM
i just used shims
and a good square
http://lumberjocks.com/projects/21465
View Nicky's profile
Nicky
695 posts in 3995 days
#2 posted 10-03-2012 01:08 AM
Take a look at http://eberhardt.bz/GME_Wood_Land/GME_Woodworking_Stuff/2_Tool_Tune_Ups/7_Tuneup_Radial.pdf
I think section 4 is what you’re looking to do to get your table level.
Also check out this video http://www.youtube.com/watch?v=QKSkZ1vAzNc
-- Nicky
wood_warrior
#3 posted 10-03-2012 07:18 PM
Shims? That’s way too simple of a solution… I think I’ll do it. Also, how is your table doing patron? I saw that used you used the single layer of 3/4” particle board, has it started sagging? What is underneath it? I really like the way you did yours but I’m concerned if I do the same thing it may not last, then again I can replace for 40 bucks right? Thanks for the links Nicky.
Not sure how much space should go between my fence and the column.
View Loren's profile
9935 posts in 3551 days
#4 posted 10-03-2012 07:45 PM
When I used a RAS a lot I would nail a piece of 1/2” ply to the particleboard
table, which kept the table from getting carved up. Some people just
dial the saw in to cut 90 degrees and use jigs to cut angles. Radial arm
saws are notorious for not going back to square after you move the
arm.
wood_warrior
#5 posted 10-03-2012 08:26 PM
I plan to leave the arm at 90 and use jigs.
#6 posted 10-08-2012 11:27 PM
in response to your PM ww
my stand is just a cab with a divider in it
the saw set on top screwed down to it
and spacers run up to hold the saw top
(this is what is ‘shimmed’ by ‘tweaking’ them
up and down from front to back)
the back has a spacer too
to ride the top on
and the fence screwed down to it
to keep it flat
i got the saw arm as square as i could
any further adjustments were in the fence itself
the right wing was in my way
to move around the workbench
so i cut it and just hinged it
and hold it up with a ‘temporary’ leg
i think this is what archimedes was thinking about
when he said
‘eureka i have found it’
but since they didn’t have particleboard in his day
he quit and found a way to lift water instead
View MonteCristo's profile
MonteCristo
2099 posts in 2091 days
#7 posted 10-09-2012 02:56 AM
I wouldn’t fuss overly. A RAS is a real workhorse for chopping up long heavy boards to rough length but you could make a career out of trying to dial it in perfectly.
#8 posted 10-09-2012 03:34 AM
i don’t know about that MC
i had three dewalts in my building interiors business
all with 8’ tables
we ripped and crosscut every thing in the interiors
set them up square
and never moved the arm
didn’t matter which my five carpenters used
they all cut perfect
take the top off and load them in the van
for the next job
radial arm saws have a bad rep
from being used on job sites by rushing carpenters
and often were set up outside on uneven ground
with nothing more than the top that came with them
and everyone making sloppy cuts with little or no outboard support
the tables and fence got so beat up they were dangerous
this was all before chopsaws
now days everyone (almost) doesn’t like them
but like any shop tool
set-up right and used responsibly
they are just as good as any tool
i use sleds on the table saw
a chop saw
and the radial arm saw
every cut is square
makes no difference
and less down time for me
View OnlyJustME's profile
OnlyJustME
1562 posts in 2280 days
#9 posted 10-09-2012 03:49 AM
I have an old MW powr-kraft ras with the original manual. i could copy the manual for ya if you want.
-- In the end, when your life flashes before your eyes, will you like what you see?
