table saw, mobile base, total lock casters
Forum topic by oldnovice posted 10-01-2012 11:22 PM 3195 views 0 times favorited 4 replies Add to Favorites Watch
View oldnovice's profile
oldnovice
6773 posts in 3336 days
10-01-2012 11:22 PM
Topic tags/keywords: table saw mobile base total lock casters
My table saw allows me to use total lock casters and I was wondering if using these over a mobile base like the HTC 3000 would be a better choice? There is much less hardware associated with using the casters.
Cost of the casters is about $10.00 less and I have used these before so I know they really totally lock for total immobility. My TS weighs about 280lbs, the casters are rated for 250lbs each and the HTC3000 is rated at 700lbs.
View HorizontalMike's profile
HorizontalMike
7749 posts in 2882 days
#1 posted 10-02-2012 12:04 AM
I used the HTC 3000 mobile base on my BS, however, I used the Grizzly proprietary mobile base for my TS:
1 G7314Z SHOP FOX ADJ MOBILE BASE-SMALL
1 G8684Z SHOP FOX EXTENSION KIT FOR G7314Z
Considering that my TS weighs more than twice what you are needing to make mobile, you are probably correct in considering the total lock casters as your solution. That being said, what I like about the mobile bases that I used is that they both offer a much wider base/footing than each of the saws alone. I do not know if that is important or not in your situation, but something to consider.
View David Craig's profile
David Craig
2137 posts in 3077 days
#2 posted 10-02-2012 12:07 AM
Hans, I would say that you would be better off just getting the casters. Purchasing the mobile base is just going to make it so that you are mounting a base on a base on top of a set of casters. The additional hardware would be overkill. Save the base purchase for a router cabinet or bandsaw where the additional hardware would provide more benefit. Also, the mobile base may raise the height of the TS to a level that may be less comfortable for you.
Just my two cents
View AJswoodshop's profile
AJswoodshop
1057 posts in 2244 days
#3 posted 10-02-2012 12:18 AM
My jointer weighs about 450lb, I have it on locking casters and it rolls great. The HTC 3000, I’m sure it’s better than locking casters. Good luck!
View toolie's profile
toolie
2120 posts in 2596 days
#4 posted 10-02-2012 12:43 AM
i have a 400 lb band saw on an htc 1000. it is a POS and will be replaced when i start using the BS more. all htc products, especially their mobile bases are, IMHO, overpriced and underengineered.
