Are glue line saw blades replacing jointers ?
Forum topic by 1yeldud1 posted 10-01-2012 08:53 PM 4913 views 0 times favorited 22 replies Add to Favorites Watch
View 1yeldud1's profile
1yeldud1
301 posts in 2950 days
10-01-2012 08:53 PM
I have been seeing a lot of jointers for sale on e-bay and craigslist and was wondering if the new saw blade technology is replacing jointers for the home wood worker, it shure seems like that the used market has had its share of used jointers for sale in the past several years and I was wondering what the opinions of the craftsman at lumberjocks have to comment on this senaro – Thanks
22 replies so far
9970 posts in 3555 days
#1 posted 10-01-2012 09:45 PM
I don’t think so.
Asian made jointers in larger sizes have allowed some people
to upgrade and sell off a smaller jointer. 30 years ago,
before Taiwan made machines entered the market,
the price tag on any new 8” or larger jointer was pretty
hefty.
Also, lots of people invest in machinery to do a home
remodel or work on a boat or some other one-off,
intending to pursue woodworking after, but ten
years later and the machines haven’t been turned on
and they decide to sell off the machinery.
View 47phord's profile
47phord
182 posts in 2145 days
#2 posted 10-01-2012 09:49 PM
No, because a glue-line blade simply makes a crisp edge. A jointer makes an edge square, something no saw blade can do on it’s own. I’m not sure why there are so many jointers on the market, though I tend to echo what Loren said on the matter.
View HorizontalMike's profile
HorizontalMike
7747 posts in 2821 days
#3 posted 10-01-2012 09:55 PM
I can only say that for me, I love the glue-line blades. However with that said, those glue-line blades only really help me with edge cuts and have little to nothing to do with flattening/jointing +8in boards. I think the blades save us time, but do not replace the need for a good jointer in our shops (hobby shop in my case).
Gerald Thompson
877 posts in 2142 days
#4 posted 10-01-2012 10:50 PM
I love glue line blades. With that said how would one use a glue line blade to joint the face of a piece of lumber?
One could make a planer sled but I still like the old and proven sequnce of milling lumber flat and square all around.
-- Jerry
View pmayer's profile
pmayer
1017 posts in 2973 days
#5 posted 10-02-2012 12:43 AM
Ask a few of the owners of the jointers on CL if they are getting rid of them because they got a better saw blade. I’d be surprised if you got that answer 1 out of 20 times. My guess is that they are either upgrading to 8”, or they just aren’t into woodworking like they thought they were going to be and they can’t justify the space that a jointer occupies.
I have a great saw blade and I still use my jointer all the time. And I recently sold a 6” to make room for an 8” jointer. :)
View knotscott's profile
knotscott
7877 posts in 3283 days
#6 posted 10-02-2012 01:07 AM
Not a chance. No blade can replace a jointer, since flattening a face is the first step in dimensioning lumber. Using any blade (or router) to edge joint without first flattening the face doesn’t ensure a perfect 90° edge.
The term “Glue Line” blade is really just a marketing phrase. Most of the better blades with 30T or more are capable of providing a glue ready edge, and even some of the better 24T blades can too.
View REO's profile
REO
928 posts in 1982 days
#7 posted 10-02-2012 04:36 AM
You will always find those that believe that it isn’t craftsmanship if you don’t do it with a particular tool associated with a craftsman. I run into it all the time in the wood turning biz. it used to be hand planes that were used to bring a board from rough to Finnish milled. some still get a tremendous satisfaction out of perfecting the craft.If you want to take a twisted board and spend the time flattening and squaring it horse around with a hand Plane. Then someone decided to power the hand plane and got the jointer and the planer or thicknesser as some would have it. For the most part in the past saw blades could not achieve a smooth enough cut and the glue line would show. Things have changed! For most they will just use a flat board to start and straight/glueline rip the thing and get on with the rest of the project. it is much faster to straighten the edges of a board on a TS than on a jointer it only takes one pass and i don’t have to worry about grain direction to avoid chip out. If i really to perform a jointer operation a good router table is much easier to control than standing a board on edge and insuring that I keep it against the fence in a vertical position.
knotscott
#8 posted 10-02-2012 07:05 AM
Here’s what most of the “straight” boards that I find at the lumber yard look like (which really aren’t straight or flat).
Most aren’t flat and straight until they’ve been face jointed and edge jointed. Edge jointing alone won’t generally accomplish what you see below unless the faces are flattened first.
View CplSteel's profile
CplSteel
142 posts in 2072 days
#9 posted 10-02-2012 08:20 AM
Depends on what you are working with. With ply a tracksaw is great. Cut it and glue it (and screw or dado it). With hardwoods you have a lot of other issues to deal with before you can assemble. A jointer is useful for making the face flat, removing all that cup and twist.
View ducky911's profile
ducky911
237 posts in 2697 days
#10 posted 10-02-2012 03:22 PM
I worked without a jointer for a long time. I would rip on the table saw and would think I had a good fit…it looked tight but when the clamp presure hit it it would want to move up or down. Now with a jointer I have noticed that I do not have that problem as much.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2018 days
#11 posted 10-02-2012 03:27 PM
As mentioned earlier… faces need to be flattened, and the edge that runs along the fence needs to be straight.
That said, I don’t often machine joint edges ripped with a good blade. I often still spring and/or match joint it with a hand plane, but clean ripping blades have definitely cut down on machine jointing after ripping.
View Finisher's profile
Finisher
31 posts in 2046 days
#12 posted 10-02-2012 03:38 PM
High tech blades that leave a glass smooth finish are great, but you have to have flat and striaght stock to begin with. A joiner is one of those pieces of equipment you probably don’t use a great deal but when you do, you’re glad you have it. joiners are a basic shop tool and serious shops can’t servive without a good 8” joiner or larger.
-- James, Michigan http://www.northcapecabinetsandmillwork.com
View REO's profile
REO
#13 posted 10-02-2012 03:40 PM
oh goodness I should have figured this would come. What is your time worth and where do you shop lol. I understand that for many it is enjoyable to prepare your stock. I worked at a sawmill that dried their material as well. One of the largest in the midwest. A proper drying procedure eliminates most of this. of course if you want to work with the elm family of trees that is another story. They can do a complete 180 in any direction and unless you really know your stuff wont lay flat in the first go round either from built in stress.
Knottscott-You must have had enough shavings to bed at least one horse stall.
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2176 days
#14 posted 10-02-2012 05:31 PM
here in hawaii I get laughed at for using a jointer a 16” and 10”.havent figured out why other then people are 2 lazy here and ignorant to know its full purpose.
View bobmcc81's profile
bobmcc81
6 posts in 2068 days
#15 posted 10-08-2012 06:22 PM
I don’t own a joiner and have great success just using a good TS blade rip. Medium pressure on the clamps and never any gaps. I use mostly home store lumber and run it through the planer to get it flat and the thickness I want. Where I do have problems and have to choose another board is the cupped board that planning only flattens it temporarily as in runs thru the planer.
What am I missing by not using a jointer?
