| Forum topic by catskinner | posted 235 days ago | 1131 views | 0 times favorited | 8 replies | ![]() |
235 days ago |
Hey Lumberjocks, I am currently working on woodcrafts with seasoned manzanita. Can anyone suggest a better technique than hand sanding for removing bark and decay? The pieces are of an irregular shape and not conducive to power sanders. I have read a little about sandblasting, and was wondering if anyone out there has any experience ( and suggestions) to share. Thanks |
8 replies so far
#1 posted 235 days ago |
Sand blasting will definitely give the wood a weathered look, while removing the bark and decay. I use a 4” hand held grinder, with a twisted wire wheel. It will get all of the bark off, and any decay it can reach. I’ve seen local guys use a pressure washer for removing bark from cedar logs. Of course, you’ll have to let them dry out again. -- Tim-- http://www.tmuli.com |
#2 posted 235 days ago |
Paint scraper? -- jay, www.allaboutastro.com |
#3 posted 235 days ago |
I took a sample piece of oak to a sandblaster to see what the effect would be like. Within a few seconds he managed to make it look like a piece of washed up drift wood from the ‘Mary Rose’. -- Do or do not, there is no try |
#4 posted 234 days ago |
I use a 10” wire wheel on a bench grinder with the guards removed. Works great but wear a full face shield! -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#5 posted 234 days ago |
Thanks for all of your suggestions! I will scout about to see if i can find someone in my area that can blast a sample for me. Has anyone heard anything concerning soda blasting? Thanks again, |
#6 posted 234 days ago |
I have seen soda blasting done on cars. It will remove paint but is gentle enough to not damage rubber weather strips |
#7 posted 211 days ago |
I’ve tried soda blasting on a small piece of white oak. I used a cheap Harbor Freight soda blaster. My air compressor couldn’t run it continuously but the wait times weren’t so long that it wasn’t usable. I used a course baking soda that was pretty aggressive and I ended up with a clean but rough surface (there was some tear-out on heavily grained areas). |
#8 posted 210 days ago |
I’d try soda way before sand if the things you are blasting will go anywhere near a planer, jointer or expensive saw blade. The sand will penetrate and essentially sandpaper your blades, soda will not and can even be washed off if need be. -- --Rev. Russ in NY-- A posse ad esse |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15803 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
