| Forum topic by Charlie | posted 230 days ago | 1457 views | 0 times favorited | 59 replies | ![]() |
230 days ago |
Best way to move this? Can this be moved just like it is? I’ve seen folks recommending that the table be removed to avoid cracking the trunions. The millright/rigger in me looks at this and (because I’m 60 now) separate the table, loosen the belt, separate the saw fro the base. So you’d basically be breaking it down into its 3 heaviest pieces. Thoughts? |
59 replies so far
#1 posted 230 days ago |
WOW! That’s a beauty, and looks as though the gray Japanning is still perfect. The cast iron table is something my Craftsman doesn’t have and I certainly wish it did. As to the move, just getting it out of the basement may be a chore if a number of steps or a 2-8 or 3-0 door are involved. Sounds like the three pieces approach is certainly a simple way to approach it. Suppose you’re using a pick-up and have the time to disassemble and reassemble it. Be sure to acquire the original owner’s manual. If he doesn’t have it get one off internet. It may have some important steps for assembly that should be acknowledged during dasassembly. Great buy! Good luck. Send pictures when reassembled and ready for your use. -- Russell Pitner Hixson, TN 37343 bassboy40@msn.com |
#2 posted 230 days ago |
Ole dummy me was moveing a 14” Sprunger bandsaw standing up in my pickup. Thought i had it tied down good for only 4 miles. NO Problem till i had to stop hard. OOPs didn’t have it tied good enough. It’s very top heavy so lay it down while moveing or IMO take it apart. Why bust a gut trying to move it in one piece. -- What started as a hobbie is now a full time JOB! |
#3 posted 230 days ago |
I would break it down. If it’s like my grizz 555x it heavier than you think. -- Don't rollerskate in a buffalo herd |
#4 posted 230 days ago |
It will be under $300. The seller and I have already discussed it at least that far. How far under $300 depends on condition and completeness. |
#5 posted 230 days ago |
I can lift (but not carry) my Grizzly which is a knock off of this model Delta, so I’m guessing the Delta does not weigh 180 lbs. I’d for sure take off the table and maybe take out the motor. That leaves a manageable 1/2 the weight, bulky but doable. And do lay it down. They are stable laying “on their backs”, i.e. riser side down. There’s nothing back there to get hurt, and you can secure it nicely in that position. Dan -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#6 posted 230 days ago |
I would say it depends on how much help you have. I moved my 16” walker turner bandsaw in one piece. It took 4 guys to get it on the truck and the kabota to get it off. If you’re talking stairs and less help, a teardown will save a lot of strain. Oh, and I’m 55, but I forget that from time to time and promptly get reminded. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#7 posted 230 days ago |
Id break it all the way down. Table off, motor off, base off. Its heavy enough and not very difficult to dismantle and reassemble. Smarter not harder. I wouldnt wanna see you out of the game because of a hernia or blown out back. Looks like a nice bandsaw in good shape. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#8 posted 230 days ago |
OK, this is interesting. I went looking for a manual for a model 52-965 and came up empty. Went to Delta’s parts web site and it referenced models 28-203 and a model 28-280. The 203 is an open stand model and the 280 is the closed stand. The model 52-965 number is apparently on the stand and I’m still not sure if that’s the stand itself or what, but I got the manual for the 28-280 and it appears to be this exact saw AND on the closed stand. Doesn’t say how to remove the table, but I can’t see that being real hard to figure out. I want to see how the motor controls and wiring are routed through the base. Doesn’t look like the base itself has much weight. It’s kinda looking like if I take the drive belt off, and unbolt the on/off switch from the saw body, I’d be able to take out 4 bolts to separate the saw from the base. If that’s the case, this could be fairly easy to break down and reassemble and nobody gets hurt :) |
#9 posted 230 days ago |
Yea it should be 4 bolts that go through the base to the bottom of the saw. Youve got it figured out. If youre hesitant to break it down snap some pictures with your phone or bring a camera along. Im a forgetful kinda fella so i take lots of pictures when taking stuff apart. Dont wanna be left with any extra wingnuts. All the weight will be in the motor, table, and upper portion of the saw. The base is just sheet metal probably. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#10 posted 230 days ago |
JUST TAKE THE CAST TABLE OFF AND YOU WILL BE FINE GET SOME RATCHET STRAPS AND TIE IT DOWN IN THA TRUCK AND IT WILL BE FINE i HAULED MY RIKON 170 MILES IN BACK OF A PICKUP 10 345 RUNNIN 65 MPH BUT I HAD IT STRAPPED DOWN WELL -- Stevo, work in tha city woodshop in the country |
#11 posted 230 days ago |
I suggest you break it down so it would be a lot easier to carry. -- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live" |
#12 posted 230 days ago |
I just brought a Central home in my Chevy HHR. Take the fence bars off the table. Bring a 24” 2×4 and four 10” 2×4s and a handful of screws. Dont forget the cordless driver. Lay the larger 2×4 under the riser and stack the smaller 2×4s alongside screwing them down to the larger. Strap down the base. DO NOT AT ANY TIME LIFT, MANEUVER, PULL OR PUSH using the table. Two MEN can lift and carry this machine up stairs with moderate difficulty. It is amazing how similar most of these 14” bandsaws look. -- Made in America, with American made tools....Shopsmith |
#13 posted 230 days ago |
Remove the table and tip it the machine onto a piece of plywood Usually one side of a machine is the one that is clearly not going I seldom move a machine upright. Most are top-heavy and if |
#14 posted 230 days ago |
charlie….... i agree with most of what i’ve heard, but i wouldn’t remove the motor. when i got an 18” rikon 10-340 from a woodnetter, it was in a basement accessed through a bulkhead covered 8 step staircase. we removed the table and wheels, strapped it to an appliance hand truck and two guys moved it up and out with no problem. that’s a 400lb. saw. yours is probably ~ 200, total and maybe 125-150 with the wheels and table removed, so it shouldn’t be at all hard for 2 able bodied men with an appropriately sized appliance hand truck. lay it on it’s spine in the vehicle and secure it so it doesn’t tip when moving. here’s a little slide show of the BS in one of out trucks. i had help loading but got it out and moved into position alone using the hand truck shown http://community.webshots.com/slideshow/583083464UrvXsH?mediaPosition=1 goog luck. -- there's a solution to every problem.......you just have to be willing to find it. |
#15 posted 230 days ago |
Just found the weight of a 28-280 on a closed cabinet base. 224 pounds. |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1525 |
3543 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6151 |
