Table saw help!
Forum topic by idiotstick posted 235 days ago 606 views 0 times favorited 14 replies Add to Favorites Watch
View idiotstick's profile
idiotstick
28 posts in 863 days
235 days ago
Topic tags/keywords: question
I have had no problem at all with my table saw for at least 5 years, but turned it on this morning and the fuse box in the workshop tripped out.
Checked wiring in stop/start switch and all seems ok. Tried again and fuse tripped again.
Any ideas what it could be or what I should check for?
Pete.
14 replies so far
View HorizontalMike's profile
HorizontalMike
4933 posts in 1085 days
#1 posted 235 days ago
Check the outlet. I know that my 240v plug end shows arc spots over time. A loose connection could be the culprit and finally opened up. Just an idea.
idiotstick
#2 posted 235 days ago
Thanks mike, will check that in the morning.
Pete.
12070 posts in 1512 days
#3 posted 235 days ago
fuse could be going too
they do wear out
View toolie's profile
toolie
1116 posts in 800 days
#4 posted 235 days ago
is the blade somehow jammed?
View cutworm's profile
cutworm
685 posts in 965 days
#5 posted 235 days ago
Does the motor hum? It the breaker trips as soon as you turn it on check for a pinched or cut wire going to the motor. Unplug the saw and start checking the wiring as soon as it leaves the switch all the way to the motor. If the wiring is good it may be a starting capacitor or starting winding depending on the type of motor in your saw.
If the motor hums for a few seconds try to turn the blade by hand to make sure there is no binding.
Lastly you can unwire the motor and tape the ends. Turn on the switch. If the breaker trips it’s a wiring / switch issue. It not it’s probably the motor.
-- "Actions speak louder than words but not nearly as often." - Mark Twain
View knotscott's profile
knotscott
4208 posts in 1547 days
#6 posted 235 days ago
What saw do you have?
View Grumpymike's profile
Grumpymike
638 posts in 486 days
#7 posted 235 days ago
Good meaty info here please let us know what you find
-- Grumpy old guy, and lookin' good Doin' it.
View OnlyJustME's profile
OnlyJustME
1381 posts in 548 days
#8 posted 235 days ago
PLEASE dont try to turn the motor by hand with it plugged in.
-- In the end, when your life flashes before your eyes, will you like what you see?
View crank49's profile (online now)
crank49
2290 posts in 1142 days
#9 posted 235 days ago
Posisible the breaker has become weak. That happens.
Is the saw 120volt.
If it is you could plug another high wattage load into the same outlet and see what the breaker does.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View joeyinsouthaustin's profile
joeyinsouthaustin
518 posts in 244 days
#10 posted 235 days ago
Echo knottscott….. What saw do you have? is a really important question.. magnetic on off.. could mean a fried capacitor in the low voltage system. other motors and systems could still be dangerous after they are unplugged, and would need the hot grounded to discharge the starting capacitor…. what saw is really important to help trouble shoot this problem. Echo horizontalmike… pics of the plug and the electrical service would help as well as model and serial numbers…they would let us know amp and other ratings etc…
shop situations… this is the time of year rodents bed down for the winter… and tend to chewww..
-- Who is John Galt?
idiotstick
#11 posted 235 days ago
Wow, unbelievable the knowledge that the members on here have to offer.
I am going to check the simpler suggestions this morning ie wiring breaks etc.
Also going to plug in another machine int the socket and check that it works ok.
The blade turns freely (With motor switched off lol)
It’s a Rexon 240volt.
Thank you all for your suggestions, very much appreciated.
HorizontalMike
#12 posted 235 days ago
Do you recall EVER dropping any piece remotely near the power cord? (think pinched cord)
View lumberjoe's profile
lumberjoe
2401 posts in 420 days
#13 posted 235 days ago
Worst spammer ever. At least get your HTML code right if you are going to embed links to increase page views.
Are you using an extension cord?
-- http://www.etsy.com/shop/KandJWoodCrafts
idiotstick
#14 posted 235 days ago
No Lumberjoe, just plugged into wall socket. Have tried plugging into a different socket, but same result.
Checked all wires for kinks, all ok.
I did take cover off the start switch box, but quickly put that back when I saw what looked like a coil and other connections, that’s not for me I think that it would be safer for me to get someone in who know’s what they are doing!! lol
Pete.
