What is the best exterior glue of bent laminations
Forum topic by Arthouse posted 09-30-2012 04:09 PM 5702 views 1 time favorited 20 replies Add to Favorites Watch
View Arthouse's profile
250 posts in 2580 days
09-30-2012 04:09 PM
I have been gluing bent lamnation for exterior use. I have used several titebond 11 , gorilla glue , and unibond 800. I used to use a two part resourseanol but can’t seem to find it . Do anyone have any experience using an exterior glue of bent laminations that will last outside in Texas hot weather.
-- "The hand is the cutting edge of the mind but the wind and sun are the healing factors of the heart
20 replies so far
View MARCquetry's profile
5 posts in 2480 days
#1 posted 09-30-2012 05:01 PM
I too live in Texas (Bryan/College Station area….Gig’Em) and have had very good luck using 2 part slow setting epoxies for bent lams both indoors and out. I prefer System 3 T-88 epoxy, but I would not hesitate to recommend the West System brand either. One hint that I would offer though…Epoxies need a little mechanical tooth to hold well in bent lams. Just make sure that all of the glue surfaces are somewhat rough before applying…you don’t want to take them straight out of the planner to glue up. One other thing about the epoxies…they are fully tintable…if your project calls for that. Personally, I like to use “TransTints”.
Hope that helps.
Good luck with the project.
View MrRon's profile
4667 posts in 3173 days
#2 posted 09-30-2012 06:35 PM
The best adhesive to use for exterior use is either a phenol formaldehyde or a resorcinol formaldehyde You can find these at a marine supply store. The following site will tell you everything you need to know about adhesive bonding.
View HerbC's profile
1726 posts in 2789 days
#3 posted 09-30-2012 06:53 PM
+1 for the resorcinol.
-- Herb, Florida - Here's why I close most messages with "Be Careful!"
View Jim Jakosh's profile
Jim Jakosh
20162 posts in 3035 days
#4 posted 09-30-2012 06:56 PM
West System Epoxy will do the trick. it is the best glue I have ever used. I built a hovercraft with it.
you will love it!...................Jim
View sras's profile
4761 posts in 3058 days
#5 posted 09-30-2012 08:08 PM
I have used both resorcinol and West Systems Epoxy. While both can be nasty to deal with, I prefer the epoxy. If the epoxy is going to be exposed directly to sunlight for a long time, a UV blocking finish should be used.
View MJCD's profile
534 posts in 2301 days
#6 posted 09-30-2012 08:31 PM
I’m using the West Systems G/Flex 650, for an exotic wood (Jatoba) outdoor bench – it comes highly recommended. Their customer service is top-notch.
The recommend cleaning the wood, post sanding, with Isoprophyl alcohol – this raises the grain slilghtly – and give the epoxy more wood fiber to adhere to. The 2-part systems require a bit more planning, they’re thicker viscosity, and a longer open/working time.
They are costly, though.
-- Lead By Example; Make a Difference
117028 posts in 3506 days
#7 posted 09-30-2012 09:52 PM
Plastic Resin glue ,slow setting and dries hard.
-- wood crafting & classes
View Joe Lyddon's profile
Joe Lyddon
10047 posts in 3982 days
#8 posted 10-01-2012 12:03 AM
a1Jim, but, on the package it says “Ideal for Interior wood application”...
... then it goes on to say it’s great against water, rot, etc. (water is present the Interior? Bathroom & Kitchen, I guess… LOL)
I remember using that stuff way back when I made my 1st professional piece of furniture in the 9th grade of school!
... we just mixed a little water with it… used it… worked great… We didn’t know there was any other kind of glue available in the early 1950’s… It worked great!
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: ... My Small Gallery:"
View benchbuilder's profile
284 posts in 2380 days
#9 posted 10-01-2012 12:09 AM
You may want to check out Raka epoxys, they are just as good as West Systems and a lot cheaper cost wise. The 605 hardner is really good to use outside. Look at the Raka Epoxies website. I have used this epoxy for 15 yrs. and never had a problem with it.
View joeyinsouthaustin's profile
1294 posts in 2002 days
#10 posted 10-01-2012 12:13 AM
texas hot is not the problem…. (central to east) humidity is.. for that I would go read more about the resorcinol. In the west expansion and contraction with a dry heat is. urethane based glues may be the answer, or stucco!! ;)
-- Who is John Galt?
View levan's profile
472 posts in 2909 days
#11 posted 10-01-2012 12:20 AM
Waterproof Resorcinol Glue is designed to laminate structural wood beams, also provides durable bonds on a variety of porous and semi- porous materials such as wood, particleboard, leather, cork, concrete (cured) and crockery (unglazed).
Resorcinol Waterproof Glue is a high performance, two component adhesive designed to provide the strongest, most durable bonds in severe service application. Once cured, Resorcinol withstands continuous salt or fresh water immersion, outdoor exposure, tropical or sub zero temperatures.
I have used this successfully for exterior projects and liked it. there are several manufactures one being weldwood.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View HorizontalMike's profile
7749 posts in 2843 days
#12 posted 10-01-2012 12:21 AM
As an Aggie and South Texas resident, I recommend West Systems Epoxy as well. I used to use this stuff to vacuum sheet Obechi veneer onto high performance RC sailplane airfoils/wings. When flying, we would have these things out under the Texas sun the entire day (at a time). Not only did the epoxy hold up, there was NO degradation in the performance characteristics of these planes at all. And I mean we pulled many Gs and high speed dives with these things.
I love West Systems Epoxy.
#13 posted 10-01-2012 12:26 AM
I used this glue on a exterior bent wood lamination 15 years ago and the piece of furniture I used it on is still in good order even after being out side all these years. Wow Joe I’m really impressed you were making professional furniture in the 9th grade. Very cool.
View MJCD's profile
#14 posted 10-01-2012 12:53 AM
For ‘joeyinsouthaustin’, more important than ‘who is John Galt’ is when in god’s name is he going to show up – we need someone who will ‘stop the engine of the world’ so that we can re-start it.
#15 posted 10-01-2012 01:01 AM
For ‘mjcd’ engine is stopped… we’re all just hangin’ up here in ‘colorado’.. chimin’ in on the internet. every one here is already re-startin it.
Sorry… cant comment more.. ’’bout to get on a high speed train to dallas, and the special metal blocks my wifi ;)
