Router Bit in Shopsmith Drill Press?
Forum topic by Don Broussard posted 09-30-2012 02:15 PM 6035 views 0 times favorited 9 replies Add to Favorites Watch
View Don Broussard's profile
Don Broussard
3547 posts in 2249 days
09-30-2012 02:15 PM
Topic tags/keywords: drill press router shopsmith duplicating question
I haven’t built a router table yet (what am I waiting for?) and I need to duplicate some simple curved patterns. Can I use a standard high speed router bit in my Shopsmith drill press turned up at high speed? I can use the bearing against the pattern down on the drill press table and cut duplicates. I think I can use this method safely, but i’d like to hear if 1) this is a useful workaround, 2) if I should just freehand it, or 3) get on with it and build the router table.
Thanks in advance for sharing your experience.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
9 replies so far
View paratrooper34's profile
paratrooper34
915 posts in 2949 days
#1 posted 09-30-2012 02:22 PM
I never tried this, but it would seem to me that the drill press RPMs (even at high) would still be way too slow for effective routing. That could lead to a hazardous situation.
I vote for number three: Build your own. Or you can find some VERY inexpensive router tables on CL and Ebay. Be safe and get the proper tool.
-- Mike
Don Broussard
#2 posted 09-30-2012 02:30 PM
@paratrooper34—I have been looking at plans for a router table, and I will build one soon. I have narrowed it down to a couple of different bench top designs. I have also been looking at CL for some good deals on a used router table.
The Shopsmith’s top speed is a little over 7,000 rpm, so it is way slower than the 30,000 rpm of my router. I certainly want to work safely, so I appreciate your comment.
Finally, thank you for your service.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2069 days
#3 posted 09-30-2012 03:16 PM
I second paratrooper34.. You could easily hurt yourself or your drill press trying this, even ruin your bit.
If it is only a simple curve, free handing it with a pattern set up should not be difficult. We do all of our pull out scoops, and other simple curves by hand, even with several router tables ready to go. I only go to them for more complicated patterns, or patterns that turn across the grain several times, like an ogee cabinet foot.
-- Who is John Galt?
View Gene Howe's profile
Gene Howe
10479 posts in 3425 days
#4 posted 09-30-2012 03:29 PM
Way too slow. Disapointingly so.
If you are duplicating, I’d use a pattern bit in a hand held router.
View NiteWalker's profile
NiteWalker
2737 posts in 2574 days
#5 posted 09-30-2012 05:00 PM
I’d take the 10 minutes needed to make a router table and do it that way.
A scrap of plywood or mdf with your router mounted into it, a straight board for a fence and you have a router table.
Don Broussard
#6 posted 09-30-2012 06:16 PM
I made my patterns this morning. For my immediate needs, I’ll freehand the workpieces from the patterns. Turns out I don’t have a pattern bit with a bearing after all. Looks like I’ll be making a trip this afternoon . . .
Thanks for the advice.
View shipwright's profile
shipwright
7980 posts in 2795 days
#7 posted 10-01-2012 01:11 AM
Have a look at this. It is set up on a ShopSmith 10ER here but any drill press will do. It is very good for following patterns. I used it that way in this blog.
Don Broussard
#8 posted 10-01-2012 01:49 AM
I got a pattern bit this afternoon and freehanded the workpieces. I screwed the pattern to a scrap piece of plywood and used double-sided tape to mount the workpiece. Worked pretty well, but now I’ve confirmed that I need a router table.
@Paul—Nice setup, using the DP as a pin router.
View REO's profile
REO
928 posts in 2071 days
#9 posted 10-02-2012 05:15 AM
the only trouble you may have is the attachment of the chuck to the drill press. if it a taper fit it can work loose and turn your chuck into a free spinning top.
