Freud Router Bits...
Forum topic by grub32 posted 09-30-2012 01:34 AM 1779 views 0 times favorited 4 replies Add to Favorites Watch
View grub32's profile
grub32
215 posts in 3070 days
09-30-2012 01:34 AM
Topic tags/keywords: router bits molding casing crown molding
I have been considering buying some of these casing bits or the Crown Bits. I was wondering if anyone has used this style architectural bits and has any insight into their quality and ease of use.
I am considering this because it will be a major cost savings for me on a few projects I have coming up. I am hoping to do it well and save a few bucks over commercially made casing and crown.
Thanks for any and all information. I truly appreciate all of your experience.
Grub
-- Educator by Day, Wood Butcher by Night!!
View knotscott's profile
knotscott
8055 posts in 3398 days
#1 posted 09-30-2012 10:58 AM
I’ve never used those specific bits, but can tell you that long pieces in particular on any routing operation using bits of that type in general is more difficult than some. So much material gets removed from the face that the material needs additional support on the exit side of the bit in order to get consistent results…if you use a traditional router table, you’ll want to add support to the outfeed side of the router fence. If you use a horizontal router table, you’ll want to add the support to the outfeed side of the table. It’s a similar concept to supporting the outfeed side in a jointer operation or edge jointing on a router table. I’d also suggest using feather boards in two directions to keep the pressure even.
View Bill White's profile
Bill White
4947 posts in 3982 days
#2 posted 09-30-2012 04:11 PM
All the Freud products I own are top notch tooling. Don’t think you’ll go wrong.
Bill
-- bill@magraphics.us
View Nicky's profile
Nicky
695 posts in 4114 days
#3 posted 09-30-2012 05:29 PM
I have the crown set. These are quality bits.
Use multiple passes and a steady feedrate for best results
-- Nicky
grub32
#4 posted 10-01-2012 12:53 AM
I will probably go and get them…I will use multiple feather boards for this application. I have a few of the Freud quadrant cutters. I can safely say I have never used a bit that cuts as nice as they do.
If the casing bits are that quality, I will be very pleased. I don’t anticipate ever cutting anything longer than 7 feet with that bit.
I appreciate the info,
Grub
