Ridgid 4424 Oscillating Spindle Sander fix
Forum topic by Backwood posted 09-29-2012 04:22 PM 2812 views 1 time favorited 6 replies Add to Favorites Watch
View Backwood's profile
Backwood
35 posts in 2209 days
09-29-2012 04:22 PM
Topic tags/keywords: tip trick sander
My Ridgid OSS would not start on it’s own anymore and I looked everywhere for a fix, and could not find one. I finally discovered that the start up problem comes from the relay connected to the switch had become fouled. Unplug the sander, turn it over and remove the feet and screws from the bottom and remove the bottom cover. The relay is right by the switch…mark the color coded connections and remove them. A single screw holds the relay together. Carefully remove it and clean the contacts inside. Replace everything and voila, the sander works as good as new. Hopes this helps someone.
View Dusty56's profile
Dusty56
11814 posts in 3564 days
#1 posted 09-29-2012 05:48 PM
Thank you …I will try to keep this in mind if mine ever craps out : )
View Gene Howe's profile (online now)
Gene Howe
9946 posts in 3304 days
#2 posted 09-29-2012 05:58 PM
Thanks. Same as Dusty.
View Richforever's profile
Richforever
757 posts in 3596 days
#3 posted 09-29-2012 07:21 PM
Thanks! My sanding sleeves slip on the cylinders, and I’m trying to figure out the best fix for that.
-- Rich, Seattle, WA
View Bill White's profile
Bill White
4823 posts in 3836 days
#4 posted 09-29-2012 07:47 PM
Slipping sleeves: Are ya using the correct washers, and are the drums clear?
Good tip on the contacts.
Bill
-- bill@magraphics.us
View Grandpa's profile
Grandpa
3259 posts in 2551 days
#5 posted 09-29-2012 08:23 PM
Slipping sleeves can usually be corrected by WASHERS and not one in my case. Thanks for the tip on the contacts
View nwbusa's profile
nwbusa
1021 posts in 2162 days
#6 posted 09-29-2012 09:08 PM
Tightening up the top screw with the correct washer in place has solved the slipping sleeves on my Ridgid sander.
-- John, BC, Canada
