I could get a free tablesaw! - update
Forum topic by Simon2822 posted 236 days ago 840 views 0 times favorited 15 replies Add to Favorites Watch
View Simon2822's profile
Simon2822
50 posts in 585 days
236 days ago
Topic tags/keywords: tablesaw
I have the opportunity to take ownership of this table saw (free of charge) but before I did I would like some expert input as to what I can do with it in terms of making it functional.
Some details:
Table size: 590×810mm
Blade size: 380mm
Max cut depth: 95mm
Blade tilts up to 45deg
Motor: 240V 3kW (4hp?)
It needs a new blade. There is currently no fence or miter slots and the table top doesn’t look like it is 100% flat, definately not smooth, at the moment. Could I put on a new top (on top of the existing)?, maybe out of quality ply to give a smooth surface (and put a couple of miter slots in) and somehow fix up an adjustable fence.
Thanks in advance for your input
Simon
-- Failure is always an option
15 replies so far
12067 posts in 1512 days
#1 posted 236 days ago
definitely worth reviving
id probably just make a complete cab base for it
with a section for the saw to fit in
(with new solid top as you described)
and an aftermarket fence
at 95 mils (roughly 3 5/8”)
you would still have almost 3” of cut depth
(that’s all i get on my unisaw)
great score
and the price is right
lucky you
View rustynails's profile
rustynails
355 posts in 699 days
#2 posted 236 days ago
I would pass on it for a table saw but get it anyways just for the motor and parts and possible the stand to be used for other things. As for the table saw part you would have to put money into it and may thoughts are its good money for bad. Used your money to buy a better saw as you will find out you will have just as much money into it as buying something else and something that has a resale value to it for later upgrades.
View knotscott's profile
knotscott
4202 posts in 1546 days
#3 posted 236 days ago
Oye! Well, the switch looks kinda neat….
View Wdwerker's profile
Wdwerker
303 posts in 404 days
#4 posted 236 days ago
I saw a picture of one of those saws before. The handle lets you make plunge cuts, kind of like an upside down chop saw. Seemed scary to me, but it is free and they are your fingers, be careful!
-- Fine Custom Woodwork since 1978
View renners's profile
renners
1892 posts in 1140 days
#5 posted 236 days ago
That’s the kind of saw that gets chucked in the back of a transit van and lugged around to construction sites for rough cutting roofs and joists.
Not sure how precise it would be for finer work, by the time you’ve got it tuned and a fence and some kind of miter fence, you might be as well buying just a a small cabinet saw.
Just my opinion.
-- Do or do not, there is no try
View IsaacH's profile
IsaacH
128 posts in 267 days
#6 posted 236 days ago
If you are the type of woodworker that spends hours truing up the souls of his planes to .000000000000001” flatness or spends half an hour using a calibrated electronic engineers square to set up for each cut… then I wouldn’t bother…. But with some fun (some might consider it work), I bet you could get a saw that could cut with a 1/64” accuracy or better.
Hell….I’d take it in a heartbeat!
-- Isaac- Decatur, GA - "Your woodworking....NOT machining parts for NASA!!!"
View syenefarmer's profile
syenefarmer
332 posts in 1251 days
#7 posted 236 days ago
That looks like a great opportunity to put a bunch of money into something that in the end won’t be worth the money you put into it.
View HorizontalMike's profile
HorizontalMike
4931 posts in 1084 days
#8 posted 236 days ago
I tend to agree with the premise that some things actually should be allowed to pass into history. This might be one of those things. Sure it could be made to run and probably run reasonably well, however, I know that I would not enjoy working with such a tool. Not trying to be a tool snob, just trying to be practical. There is nothing visually pleasing about neither form nor function, so I would personally pass on this. Just my opinion…
IsaacH
#9 posted 236 days ago
.....hmmmm, maybe I need to rethink my position after reading HorizontalMike’s post.
I was concentrating on the fun of the build and the possible results. The possible result might not be a practical result. If it was a real pain to use you might give up on tablesaws all together,
if you give up on table saws, you might give up on woodworking all together
if you give up on woodworking, you might spend more time bothering your wife/girlfriend
if you spend more time bothering your wife/girlfriend, she may make you go antiquing,
If you go antiquing, you might decide you like the needlepoints they are selling,
if you decide you like needlepoint, you might take it up as a hobby!
if you take up needlepoint as a hobby, you might start hanging out drinking tea with little old ladies
if you drink tea with little old ladies, you might spill and burn youself.
Please dont burn yourself.
Simon2822
#10 posted 236 days ago
Thanks for all the responses. I have decided it will be going in the boot of my car tomorrow. I have a lot of the materials I may need already and can get hold of / have made anything else at a reasonable price. My next days off will be spent investigating, stripping down the saw (I know the motor runs) and rebuilding. It’ll be a fun project to spend the next few weeks on. I’ll try and remember to take a few in progress photos and let you all know how it goes. Worst case it is a free 4hp motor for use on something else.
View Loren's profile
4893 posts in 1818 days
#11 posted 236 days ago
That’s a European style of portable saw. North Americans
have barely seen such things. As mentioned, it can
plunge from below like a “jump saw”, which is a production
tool. The large blade diameter allows long and heavy
beams to be clamped to the table and cut by raising the
blade.
The miter gauge and fence tend to be rudimentary
fixtures which ride or clamp to rails on the left side of the
table and the front.
View Dusty56's profile
Dusty56
10515 posts in 1858 days
#12 posted 236 days ago
I hope that you’ll post this when you get it reconditioned….first one of these that I’ve ever seen : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View Jerry's profile
Jerry
1431 posts in 1717 days
#13 posted 236 days ago
If it were me I would take it for “free” and re purpose whatever I could such as the motor, which is worth the asking price.
But to rebuild as a table saw, that likely would not be economical considering what you would need to spend compared to what can be purchased on CL.
-- Jerry Nettrour, San Antonio, www.topqualitycabinets.net
View Rick M.'s profile
Rick M.
1492 posts in 551 days
#14 posted 236 days ago
You could make a dedicated rip saw if the mechanicals run true.
-- -- Rick M.
Simon2822
#15 posted 166 days ago
Well it is not yet complete, I still have a fence to sort out (currently using a clamping straight edge) and I have plans for a cross cut sled and blade guard (including some form of extraction port). Here are some pictures of progress so far:
First job – remove the old legs
Then add a new frame (chunky 3” legs)
Then a new top
The top is made of a sheet of 3/4” ply topped with a 1/8” sheet of MDF to give a really smooth top. Two mitre slots added (t-track to be added soon) and a zero clearence insert.
So far it has only been used to cut plywood but has performed well.
Accuarcy – On a 3’ length of ply the thickness of the cut piece varied less than 0.02” across the whole length.
Cost – (£30 for wood I hadn’t already got, £35 for a new 400mm Bosch optiline (60 teeth) blade giving an 75mm cut depth)
