| Forum topic by whitewulf | posted 232 days ago | 381 views | 0 times favorited | 4 replies | ![]() |
232 days ago |
I found this old plane, a # 5 maybe, based on size. My new old stock Stanley blade & iron fit perfectly. Adjustable frog fine adjustment knob, grooved sole. No markings at all. Properly Adjusted it works fine. Missing centering lever and ?? Where should I look for spare parts? A drawing would be helpful if I have to make one. Thanks in advance, Paul -- "ButI'mMuchBetterNow" |
#1 posted 229 days ago |
How about just a picture Paul ? -- Glen, Vernon B.C. Canada |
#2 posted 229 days ago |
Is this it? Before those planes got a LATERAL adjuster, the plane operator would tap the side of the iron with a small mallet/hammer to adjust the side to side. Used the same to set the depth of cut as well. One could go looking on Ebay for a Frog as it is called. be sure that it matches the base you have. They run about $5-15 for a good one. -- A Planer? I'M the planer, this is what I use |
#3 posted 229 days ago |
Just to reiterate here, all #5 size frogs aren’t compatible. Stanley frogs won’t fit on Sargent bodies and vice versa, for example. Post a picture of your frog and body. If your lateral adjuster is missing, as opposed to never having been there, you’re probably going to just have to buy a new frog, as repairing it will probably cost more than the replacement frog. -- ian | "You can't stop what's coming. It ain't all waiting on you. That's vanity." |
#4 posted 229 days ago |
Appreciate the response. Trying to get pics, had to do some cleanup. The adjuster is just missing, I can use the plane as is, just thought I might try to complete it. I have several Woodies, am familiar with tapping to adjust. More to follow. -- "ButI'mMuchBetterNow" |
| Forum | Topics |
Woodworking Skill Share
8782 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15752 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
