Save me from a foolish mistake with Canola Oil
Forum topic by Murdock posted 09-28-2012 11:14 PM 5498 views 0 times favorited 27 replies Add to Favorites Watch
View Murdock's profile
Murdock
128 posts in 2447 days
09-28-2012 11:14 PM
Topic tags/keywords: question oil finishing oak
Due to a really stupid move on my part I spilled Canola oil on a nearly finished side table project made with Red Oak. Had it in the kitchen to show it off to some friends and was trying to cook with it sitting there.
I wiped off the bulk of the oil with paper towels, but of course some soaked into the surface.
What is this going to do to me when it comes time to finish? I am planning on using a golden oak watco oil for this project.
Will this ruin my finish? will it go rancid down the road? do I need to remove the affected pieces and start over? Really don’t want to have to do that.
-- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein
27 replies so far
View HorizontalMike's profile
HorizontalMike
7749 posts in 2877 days
#1 posted 09-28-2012 11:25 PM
Lacking in knowledge on the matter, I would probably coat the entire piece with canola oil, wipe off, let dry, and then continue with your original plan for finishing.
View Moron's profile
Moron
5032 posts in 3856 days
#2 posted 09-28-2012 11:26 PM
acetone might help, albeit very explosive but it will dissipate the oil with multiple applications
Years ago I did the same thing, and the marks are still there today but I didnt use acetone/alcohol/naptha
You might be best to remove affected parts
View Dallas's profile
Dallas
3599 posts in 2450 days
#3 posted 09-28-2012 11:33 PM
Rape seed oil, (Canola), will go rancid over time, but if you wiped it up quickly and inundate the surface with mineral oil, then use your Watco finish it should be OK.
What will happen is that the mineral oil should mix with the Canola and dilute it to the point that it’s a non issue.
If not, you can use the old acetone trick to draw the oil out, but with red oak it will probably go on through to the bottom.
HorizontalMike
#4 posted 09-28-2012 11:40 PM
What these folks are saying is that these solvents will dilute the canola oil, NOT remove it. That said, I would STILL recommend cover ALL, wiping it off, THEN try using the solvents. This way ALL of the project will at least be treated equally and you just MIGHT end up without streaks. NO guarantee, but what is there to lose at this point.
Murdock
#5 posted 09-28-2012 11:58 PM
Thanks for the suggestions guys
I am inclined to go the route of covering at least the top where the majority of the hit with canola is as HorizontalMike suggests then wipe off and then try the acetone
I guess if it goes bad then I can replace the parts, it is the top and some dripping on a side, I am thinking that the side won’t be too noticeable.
View crank49's profile
crank49
4030 posts in 2934 days
#6 posted 09-29-2012 01:06 AM
You could seal it with dewaxed shellac, but I don’t know how that would affect your finishing plans.
View longgone's profile
longgone
5688 posts in 3271 days
#7 posted 09-29-2012 01:11 AM
I also agree with covering the entire top with canola oil and blend in the stained part.
Canola oil is great for making a roux but never used it for a wood finish before.
View JJohnston's profile
JJohnston
1622 posts in 3254 days
#8 posted 09-29-2012 01:20 AM
You might try “whiting” along with the acetone. It’s sold by gunsmith suppliers, buti t’s nothing but chalk dust. You mix it with the acetone to make a paste and slather it on. The acetone dissolves the oil and the absorbent quality of the chalk helps draw it out.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View madts's profile
madts
1855 posts in 2303 days
#9 posted 09-29-2012 01:32 AM
I will say any vegetable oil is oil. Just do NOT use engine or transmission oil!
-- Thor and Odin are still the greatest of Gods.
View Clint Searl's profile
Clint Searl
1533 posts in 2324 days
#10 posted 09-29-2012 02:11 AM
The previous comments have no basis in chemistry or experience. All you need to do is scrub it well with a strong solution of dishwasher detergent and hot water, followed by a hot water rinse. Repeat. After it dries, proceed with your usual finishing schedule.
JJohnston
#11 posted 09-29-2012 02:19 AM
Well, no experience other than that I’ve used whiting & acetone to draw old cosmoline out of wooden rifle stocks, that is.
View Deycart's profile
Deycart
444 posts in 2221 days
#12 posted 09-29-2012 08:00 AM
After following everyone’s advise I would try to use some japan dryer on it to get the residual oil that you cant get out to harden. Just use a generous amount of it and do it outside!
Clint Searl
#13 posted 09-29-2012 08:50 AM
JJohnston—-You’re wasting money on the acetone when mineral spirits or naptha will work better.
Deycart—-Japan drier will have no effect on an oil that does not polymerize.
View Grandpa's profile
Grandpa
3259 posts in 2638 days
#14 posted 09-29-2012 08:37 PM
I agree with H-Mike when he says the solvents will dilute the oil and allow it to go further into the wood. Anyone here ever remove an oil spot off wallpaper? Use talc and let it draw the oil out. I think I would try to dilute it with a solvent and then place the table (oily side down) onto some corn starch that is spread evenely on some newspaper. Let it sit for a day or two then vacuum the corn starch out of the pores of the wood.
Moron
#15 posted 09-30-2012 01:46 PM
Certainly no chemist here but I did own an old antique boat where I had to paint the bottom of the hull that was saturated in engine oil. A local boat builder recommended I use acetone (outside ) and I did. I poured acetone on the inside and much to my surprise the oil started dripping from the underside of the hull and pooled on the top so I could remove the oil.
Having said that, …………. it sounds like an easy solution is to start over : ((
