Question on table with leaves
Forum topic by Monte Pittman posted 09-28-2012 09:50 PM 754 views 0 times favorited 6 replies Add to Favorites Watch
View Monte Pittman's profile
Monte Pittman
29233 posts in 2338 days
09-28-2012 09:50 PM
Topic tags/keywords: question pine finishing
Is it wrong to think I can finish full length table top and then cut sections out for the leaves to keep the grain pattern for the full length of the top?
View Clint Searl's profile
Clint Searl
1533 posts in 2362 days
#1 posted 09-28-2012 10:00 PM
Sure, why not?
Monte Pittman
#2 posted 09-28-2012 10:17 PM
Paranoid that I’ll screw something up
View Roger's profile
Roger
20928 posts in 2804 days
#3 posted 09-28-2012 11:13 PM
Why not just cut it first, then finish? I’m not gettin why finish first??? I’m puzzled
404 - Not Found
2544 posts in 2970 days
#4 posted 09-29-2012 12:26 AM
By finish you mean glue together, sand down, then cut? Not glue together, sand down, finish and then cut – as Roger seems to think.
You could do that, but don’t do any final sizing/edge routing until you’ve cut it all up and put it back together again – using the hardware – especially if the extension is done with butterfly leaves. The reason to do this is to take into account the saw kerfs and clean up,and to keep the edge perfectly inline.
Monte Pittman
#5 posted 09-29-2012 12:39 AM
Sorry, didn’t mean total finished. Just want to make sure I am not missing something obvious.
View knockknock's profile
knockknock
446 posts in 2173 days
#6 posted 09-29-2012 02:01 AM
If you want the obvious. Assuming your leaves are going in the center. If you normally use the table without the leaves, by cutting the leaves out of the center, the 2 ends of the table won’t match.
